Newbie
Andrew Stevens 303/12/2020 20:21:41
4 forum posts
Recently joined because of an interest in live steam locomotives and hoping to free up time to indulge, I have also got a 1935 Morris as a second car. An RF engineer by profession, I have done a small amount of work with lathes and mills in the past
David George 104/12/2020 07:36:45
2110 forum posts
565 photos
Hi Andrew welcome to the forum. There are loads of steam enthusiasts on here and of you need any help just ask. What does a RF engineer do.
David
Steviegtr04/12/2020 08:18:43
2668 forum posts
352 photos
Hello & welcome Andrew. What model is the old Morris.
Steve.
Brian H04/12/2020 09:03:32
2312 forum posts
112 photos
Hello an welcome Andrew. Like Steviegtr, I am interested in the Morris although I was always more into Austin 7s.
Howard Lewis04/12/2020 09:20:25
7227 forum posts
21 photos
Welcome!
A 1935 Morris should keep you occupied!
Whatever your query, someone on here should be able to help.
Whereabouts are you located?
If you can find a Model Engineering Club near you, my advice would be to join, to meet fellow enthusiasts.
No doubt, fellow classic, or should that be vintage? car enthusiasts will beat a path to your door to make bits for them.
But, if you have not already met some, beware the chap who brings a total basket case and says "Can you just? Shouldn't take you long"
Andrew Stevens 304/12/2020 18:54:16
4 forum posts
David,
I design antennas and related products for use on aircraft
Andrew Stevens 304/12/2020 18:54:50
4 forum posts
Brian H
The car is a Pre-series Morris 8
Howard Lewis04/12/2020 19:06:54
7227 forum posts
21 photos
Ah! take out the engine to speed up setting valve clearances!
My brother had one; as did my father for a while, in 1947, waiting for his new car to arrive.
Both had wire wheels, rather than the pressed steel disc wheels on the later ones.
I believe that it needed three spanners, unless you put a plate between adjacent cam followers to prevent then from turning while you actually made and locked the adjustment.
At least on the Series E you could access the tappets through a panel in the front whee archl. Didn't stop me dropping a valve collet into the sump! Fortunately, the local dealer had one, so maybe it was not unusual
Taught me to block the drain holes with rag!
JohnF04/12/2020 19:07:43
1243 forum posts
202 photos
Welcome Andrew, you will find this a very useful resource, lots of knowledge you only need to ask ! My first car was a Morris 8 1938 series 2 with easy clean wheels - as opposed to spoked wheels. Learned to drive in it and had it and eventually sold it for £18 - 10s early 1960’s
