Andrew Tinsley | 26/11/2020 11:42:05 |
1817 forum posts 2 photos | I remember a thread that Neil did, comparing 4 or 5 digital calipers, maybe a year or two ago. I now cannot find it. Can anyone help? I know there was a similar article in MEW maybe 5 years ago, but it is the forum thread that I would like to find. Andrew. |
JasonB | 26/11/2020 11:45:23 |
![]() 25215 forum posts 3105 photos 1 articles | Funny what you find by searching "Digital Calipers neil" |
Henry Brown | 27/11/2020 10:09:10 |
![]() 618 forum posts 122 photos | Reading through Neil's old post I noted Bill Phinn mentioned carbide jaws on his Mitutoyo. I quite fancy another DVC, as my old Linear one is getting on a bit. Despite concerns about worn jaws I'll maybe take a chance on a second hand Mitutoyo if I can find one local that I can see before buying. Is there a model number for the carbide jaw version or are they all the same? |
Andrew Tinsley | 27/11/2020 10:50:41 |
1817 forum posts 2 photos | Thank you Jason, just the job. I must have put in a variety of search "words" but didn't hit the jackpot. Mind you the search engine on Ebay is even worse. Andrew. |
Andrew Tinsley | 27/11/2020 10:56:36 |
1817 forum posts 2 photos | Hello Jason, I did find the thread that you linked to. It certainly wasn't the one I was looking for. That thread was far more detailed, could be that I have it confused with the original MEW article, although I don't appear to have that copy of MEW. Thanks anyway, Andrew. |
Ramon Wilson | 27/11/2020 10:58:58 |
![]() 1655 forum posts 617 photos | Well this is topical - my old long serving Mitutoyo calipers have just this morning finally given up the ghost - only put a new battery in yesterday. I don't use them for accurate measurement but they do get constant daily useage. I looked on Ebay but with an average price of under a tenner in the first xxx I looked at I came on here to see if there was anything better to be recommended. This pair must have lasted well over thirty years - the next don't need to as I won't be around by then but I would like something decent but not at Mitu prices I'll check out Neil's post but any recommendations? Regards - Ramon |
John Haine | 27/11/2020 11:05:27 |
5563 forum posts 322 photos | Just to remind people that the "search" facility that you can use by entering keywords into the boxes at the top of the thread is not fit for purpose. But if you go to the homepage and scroll down you can find a Google custom search box which works much better! I suspect that's the one that Jason entered those keywords in. |
Jon Lawes | 27/11/2020 11:25:16 |
![]() 1078 forum posts | I've just bought some of M&W budget range and they seem very good for the money. |
jason udall | 27/11/2020 18:13:13 |
2032 forum posts 41 photos | Carbon fiber framed are available.. Around Fiver each.
Can't say I've experienced them but frames made of low thermal and drill able material has potential of adding simple direct measurement to various axis . |
JasonB | 27/11/2020 18:38:58 |
![]() 25215 forum posts 3105 photos 1 articles | It was indeed the homepage search box that I used John, The next result down from the thread was the digital version of Neil's article for those that don't have the mag |
Ronald Morrison | 28/11/2020 12:10:27 |
98 forum posts 4 photos | Posted by jason udall on 27/11/2020 18:13:13:
Can't say I've experienced them but frames made of low thermal and drill able material has potential of adding simple direct measurement to various axis . I have a cheap carbon fiber digital caliper. I use it all the time but I do note that the accuracy is only 2 digits imperial instead of the 3 digits of the stainless steel one. Quick measurement to get an idea of the size, the carbon fiber framed one works fine. If I need more precision the stainless steel one comes out. |
Henry Brown | 29/11/2020 21:43:10 |
![]() 618 forum posts 122 photos | Allendale/Machine-DRO have extended their 10% off pre VAT sale until tomorrow if you fancy something mentioned in Neil's article... Edit: discount code is BLACK10 Edited By Henry Brown on 29/11/2020 21:44:50 |
