rounding off lever ends
Bill Dawes22/11/2020 19:24:27
605 forum posts
I have finally admitted defeat and given up trying to file a nice radius at the end of a drilled lever. Decided to try the milling method where you feed it gently by hand around the cutter. Made a simple pivot to try it out on a scrap piece and was quite pleased with result. Think i would like to make a more sophisticated jig that can easily be fitted with various size pins to suit hole diameter. Anyone know of suitable designs published anywhere?
Bill D.
blowlamp22/11/2020 19:46:06
1885 forum posts
111 photos
Use a bolt and some close fitting washers assembled to the lever, to serve as a filing guide.
Martin.
Clive Brown 122/11/2020 20:42:10
1050 forum posts
56 photos
Dunno about a design, but I made a "toolholder", rather like a boring-bar holder, for my lathe in which pins of different diameter could be fitted at centre height. The pins were actually stepped in diameter so they all fitted in the same holder. Worked well for reasonably small workpieces.
larry phelan 123/11/2020 11:11:58
1346 forum posts
15 photos
Is that not what they use filing buttons for ? Seem to recall seeing them mentioned many times over the years, and you dont even need a milling machine.
Andrew Johnston23/11/2020 11:48:03
7061 forum posts
719 photos
Posted by larry phelan 1 on 23/11/2020 11:11:58:
That's what I mostly use. I have used a rotary table for rounding ends, but I'm not a fan of the method. It's too darn easy to go a gnats whatsit too far leaving a slight indent in the straight edge. Once done it seems to need an inordinate amount of filing to get rid of the indent. With filing buttons it's much easier to blend the curve and straights, even if everything isn't quite perfectly aligned. I'm in the "filing buttons are unhardened and recycled after the job is complete" school.
Hopper23/11/2020 11:59:26
7881 forum posts
397 photos
I've found if you leave the nut and bolt through unhardened filing buttons a bit loose so the buttons can spin they dont get chewed up by clumsy filing and can be used again and again.
JA23/11/2020 13:15:17
1605 forum posts
83 photos
Filing buttons made from silver steel and hardened. Hardened mainly because I like using a propane torch.
JA
Ian Hewson23/11/2020 13:55:12
354 forum posts
33 photos
If you have a belt linisher they are great for rounding ends etc, even the cheap ones work well, saves a lot of filing.
learned to file and hacksaw 60 years ago at the R.o.f Barnbow, and it taught me that a machine was much better sweating over the work than me.
Ian
