Caterham tacho - possible use to show RPM
Frances IoM15/11/2020 14:45:45
1395 forum posts
30 photos
One of the many items acquired at auction sale for little outlay was Caterham tacho - EET3-1A32-00B marked as 0-8000 rrm (dial just 0-80) 4cyl - it as a strange to me 6 pin connector - I can find no info as to how to drive it - my idea is to use a cheap arduino to interface - can anyone advise - it looks undamaged and case is marked ok but I have no guarantee it still works sorry title should be RPM of my mill
Edited By Frances IoM on 15/11/2020 14:46:38
Fixed the title typo for you! Dave
Edited By SillyOldDuffer on 15/11/2020 14:54:42
Michael Gilligan15/11/2020 15:15:37
23121 forum posts
1360 photos
I would start by looking here: **LINK**
https://www.lotus7.club/forum/techtalk/random-rev-counter
and continue by wondering if it’s worth more to them than you could buy an alternative for.
Frances IoM15/11/2020 15:49:11
1395 forum posts
30 photos
can't see any help there, could you please point out anything I missed - what I need is the pin-out (+ possibly a reference to the connector tho I guess I could work thru the many hundred RS sell) as well as possibly the functions of the 6 dip switches accessible from the rear - I doubt if it is worth much but having a brother who has a Lotus I'm aware of the cost of repairs. It is just an attractive instrument 80mm diameter
Pete Rimmer15/11/2020 15:55:56
1486 forum posts
105 photos
If it says 4 cyl on it then it's probably an electronic one triggered by the coil low tension side or even an inductive pickup. When you buy after-market ones they usually have a selector switch to set the number of cylinders so that it reads true, because different number of cylinders usually means different number of pulses per rpm.
Michael Gilligan15/11/2020 20:15:19
23121 forum posts
1360 photos
Posted by Frances IoM on 15/11/2020 15:49:11:
Sorry to have wasted your time ... I presumed that, as they were discussing the existence of two different pin-outs, it might be worth contacting them.
Steviegtr15/11/2020 20:47:21
2668 forum posts
352 photos
Posted by Michael Gilligan on 15/11/2020 20:15:19:
Ditto, i would have thought that to be the perfect place to get info.
Maurice Taylor15/11/2020 21:21:24
275 forum posts
39 photos
Hi, this might be useful. **LINK**
Maurice
Maurice Taylor15/11/2020 21:32:18
275 forum posts
39 photos
Posted by Michael Gilligan on 15/11/2020 15:15:37:
Hi ,this link gives you the name of the maker .Put name in google ,to find website ,this has instructions for gauges .
I think you might be able to drive it direct from a Hall sensor
Maurice
Edited By Maurice Taylor on 15/11/2020 21:51:20
Jon Lawes15/11/2020 21:38:01
1078 forum posts
I'd be tempted to sell it and use the money to buy something more fit for purpose.
Frances IoM15/11/2020 23:13:49
1395 forum posts
30 photos
I could easily just use a 4digit display as a purely functional display but I fancied something different - I have no idea if it actually works as I took a punt on it,for I think 1 or 2 pounds, at the local auction where sometimes I have struck lucky in that no-one had recognised a specialised tool or item - tho I usually avoid items I can't physically handle and inspect, I have been tempted and often get a dud where an obvious non-working device has been repackaged to appear new - eg in one case I bought an extractor fan in original packaging only to discover that the fan blade behind the grill was absent - deceptive sales are not restricted to Ebay but at auction houses there is seldom any come back - caveat emptor strictly applies.
I had discovered previously the same thread but was confused by mention of lights as mine appears to have no visible indicators - catch is I cannot extract it from the case - the front bezel once a rubber seal in moved can be twisted but doesn't want to come away from the 'can' protecting the mechanism
Maurice Taylor15/11/2020 23:37:14
275 forum posts
39 photos
Posted by Frances IoM on 15/11/2020 23:13:49:
Hi ,Have you had a look at makers website and downloaded instructions ? Why do you need to get it out of case,connections and switches should be on back.
Maurice
