Help with Myford super 7 broken parts
M A24/10/2020 15:40:52
7 forum posts
Hi,
I have recently acquired a Myford super 7 Mk1 but it has a broken countershaft arm and drive belt cover. Will a Myford super 7 Mk2 countershaft arm fit on a Mk1?
Thanks
Steviegtr24/10/2020 18:38:49
2668 forum posts
352 photos
Not sure of the answer to this one. The MK1 & MK2 have different clutches, but don't know if the casting is different for the counter arm. I could take some close up pictures of my Mk 2 super 7B if you want. Could post them on here for you.
Steve.
If you P.M your email address i can send you the full parts manual in PDF form. I think it is for my model , but you could compare with it.
Edited By Steviegtr on 24/10/2020 18:42:47
M A24/10/2020 19:06:57
7 forum posts
HI,
If you post some close up pictures it would be great as i have the broken countershaft arm although it is in three parts and I could compare them.
Thanks
Steviegtr24/10/2020 19:11:35
2668 forum posts
352 photos
Just going to take some shots. Back soon. Hope you got the manual i mailed you.
Steve
Steviegtr24/10/2020 19:52:45
2668 forum posts
352 photos
Here are 7 pics at close range.
Steve.
Steviegtr26/10/2020 02:52:27
2668 forum posts
352 photos
Well a simple thank you would have sufficed.
Steve.
not done it yet26/10/2020 06:14:07
7517 forum posts
20 photos
I expect suitable pics are already on ‘goggle images, other forum threads, members albums, epay etc? Never mind, perhaps the OP has not been on line since?
M A26/10/2020 09:28:13
7 forum posts
Sorry for not replying. Thankyou for the pictures they have been very helpful. I have just realised that the clutch casting is also had parts chipped off so I may have to replace the countershaft and clutch.
Thanks
Steviegtr26/10/2020 14:10:51
2668 forum posts
352 photos
Ah the dreaded clutch. A friend of mine was recently brazing one that had cracked. No parts available for the MK1. Not sure if i saw somewhere that someone had made one from a Moped front drum brake.
Steve.
larry phelan 127/10/2020 16:25:01
1346 forum posts
15 photos
What ???? No parts available for a Myford !!!
What is the World coming to ?
Steviegtr27/10/2020 16:53:24
2668 forum posts
352 photos
Posted by larry phelan 1 on 27/10/2020 16:25:01:
The old style clutch is one of the few parts no longer available for the myford. I believe there is a mod that can be done to rectify this.
Steve.
V8Eng28/10/2020 11:16:53
1826 forum posts
This guy might be worth trying for difficult to get Myford parts, I have often seen his adverts.
Quillstar
Edited By V8Eng on 28/10/2020 11:17:14
Hopper28/10/2020 11:29:19
7881 forum posts
397 photos
Posted by Steviegtr on 26/10/2020 14:10:51:
.... Not sure if i saw somewhere that someone had made one from a Moped front drum brake.
Steve.
That was Myford themselves! The MK1 clutch was reputedly the brake off a Raleigh moped. Dickiest operating mechanism ever but it must have worked.
Steviegtr28/10/2020 23:16:39
2668 forum posts
352 photos
Posted by Hopper on 28/10/2020 11:29:19:
Steve.
Hopper the Mk 1 clutch was a cast iron split ring. that grabbed onto a drum. Or did it push out on to a drum , cannot remember. The ring can snap as a friends did. The mod i saw was using a moped front drum brake. With the brake shoes acting on a outer type drum. Wish i could find it. Maybe some others have seen it done.
Steve.
Hopper29/10/2020 04:31:47
7881 forum posts
397 photos
Posted by Steviegtr on 28/10/2020 23:16:39:
Steve.
Steve.
That's the first clutch on the MK1 Super 7. The very first Myford clutch, fitted to the ML7 before the Super 7 was invented, was a factory modified and fitted Raleigh moped brake whose shoes gripped the outer drum when the moped brake arm was operated by a djcky linkage from the central shaft.
Edited By Hopper on 29/10/2020 04:37:35
Steviegtr29/10/2020 13:51:38
2668 forum posts
352 photos
Posted by Hopper on 29/10/2020 04:31:47:
Steve.
Steve.
Ah right Hopper got it. I knew i had seen it somewhere.
Steve.
