Member postings for M A
Here is a list of all the postings M A has made in our forums. Click on a thread name to jump to the thread.
Thread: Help identify Myford super 7 cross slide enplate material
04/03/2021 11:59:30
Hi,
Thank you for all of your replies and advice. I think i'm going to try and use a aluminium weld rod, possibly: **LINK**or Lumiweld and hope it will hold up untill I can fabricate a new one.I'll try and fabricate a new one on the lathe once I get it operational. I think the PXF bracket will be to long for the cross slide feed screw.
Thanks
03/03/2021 22:27:21
Here are the dimensions, they are not the most accurate as it is hard to mesure in 2 pieces. Thanks for the replies and advice Noel and Johnimg_20210303_222014407.jpg
03/03/2021 21:34:06
Thanks for the response MichaelG,
I'm Probably going to try and solder it and see if it holds up
Thanks
03/03/2021 21:09:01
Hi,
I am trying to work out the material of a Myford super 7 cross slide endplate non power feed as it is broken and I was woundering if it is possible to weld it. Currently I carnt seem to find a replacement online as myford have sold out of the raw castings.
The part I have is non magnetic, feels to heavy to be aluminium, is cast, and does not spark when touched with an angle grinder.
Also does anyone know if the Power cross feed endplate would fit a non power cross feed lathe
Any help will be much appriciated
Thanks
Thread: Help with Myford super 7 broken parts
26/10/2020 09:28:13
Sorry for not replying. Thankyou for the pictures they have been very helpful. I have just realised that the clutch casting is also had parts chipped off so I may have to replace the countershaft and clutch.
Thanks
24/10/2020 19:06:57
HI,
If you post some close up pictures it would be great as i have the broken countershaft arm although it is in three parts and I could compare them.
Thanks
24/10/2020 15:40:52
Hi,
I have recently acquired a Myford super 7 Mk1 but it has a broken countershaft arm and drive belt cover. Will a Myford super 7 Mk2 countershaft arm fit on a Mk1?
Thanks
