Putting some grip (stippling) on an aluminium drive pulley.
Blue Heeler16/10/2020 23:18:57
342 forum posts
I've always wanted to work out a way to put some extra grip on a home made drive pulley to prevent or cut down on belt slippage. It would be nice to have the tooling that Wilesco use on their grooved pulleys. I had a Dremel saw accessory that the outer plastic shell broke and I thought what can I do with the saw blade. Rudimentary, but it worked well. I should be able to work out now a way to mount it so it doesn't need to be held, though its not as dangerous as that looks and being hand held allowed me to skew the saw blade at the various angles needed easily.
Paul Lousick17/10/2020 06:09:04
2276 forum posts
801 photos
Use the technique for cutting a worm wheel with a thread tap.
Paul
Blue Heeler17/10/2020 06:12:29
342 forum posts
I'd love to try that Paul.
Henry Artist17/10/2020 07:28:51
121 forum posts
46 photos
What an ingenious idea Jim! yes
It's amazing what can be achieved with very simple tools.
Old School17/10/2020 08:23:04
426 forum posts
40 photos
I found spiral flute taps worked better when I was doing the starting grove in steel flywheels for model boats.
oldvelo17/10/2020 08:32:26
297 forum posts
56 photos
Poly Vee Belt 2 Ribs "j" 4.64 mm wide will do the job.
Pulleys in aluminium are easy to fabricate with a high speed steel tool ground to 40 degrees.
Eric
Clive Brown 117/10/2020 08:38:06
1050 forum posts
56 photos
OK for a starting cord, but I'd guess that a belt running continuously on such a pulley would hve a short life.
John Haine17/10/2020 09:23:45
5563 forum posts
322 photos
Depending on the vee angle, roll the pulley hard against a triangular or square file.
Dave Halford17/10/2020 10:24:32
2536 forum posts
24 photos
Posted by Clive Brown 1 on 17/10/2020 08:38:06:
I'm assuming this pulley is for a mamod style metal spring 'belt' otherwise Picador + every car maker from the invention of the car dynamo up till the poly vee belt got it wrong.
old mart17/10/2020 19:58:53
4655 forum posts
304 photos
I'm with Dave Halford, the grip will be great, but belt life will be short. Make sure you have a good supply of belts.
Blue Heeler25/10/2020 03:27:51
342 forum posts
Worked out great for its intended purpose running small steam toy accessories (that some are prone to slippage) no wear on the green watchmakers lathe belt.
