John Button 1 | 10/10/2020 06:35:19 |
2 forum posts | What should be the optimal end float for the lead screw please? I have recently bought this lathe with end float measuring 2.7mm/0.106 inches. If this gap requires adjustment any help would be appreciated. |
Tony Pratt 1 | 10/10/2020 08:15:49 |
2319 forum posts 13 photos | As little as possible without binding,I can't see it being critical but 2.7 mm is a hell of a lot of end float. Tony |
Alan Donovan | 10/10/2020 08:21:03 |
81 forum posts 41 photos | Hello 2.7mm end float is far far too much. It should be approaching zero mm and ‘free to rotate’, not clamping the lead screw. Best regards. Alan |
David George 1 | 10/10/2020 08:35:38 |
![]() 2110 forum posts 565 photos | Hi John welcome to the forum. Is the actual leadscrew moving or is the saddle moving when engaged. If the leadscrew is not moving but there is that much play in the nut it needs replacing.
David |
Martin Kyte | 10/10/2020 09:25:27 |
![]() 3445 forum posts 62 photos | Posted by David George 1 on 10/10/2020 08:35:38:
David Or at least adjusting regards Martin |
Nick Hughes | 10/10/2020 10:27:59 |
![]() 307 forum posts 150 photos | Discussed before here:- **LINK** |
