Clive Barker | 06/10/2020 09:40:16 |
![]() 55 forum posts 29 photos | Does anyone know where I can get a 27 tooth 16DP steel gear made. 27 teeth is not a stock item. Many thanks. |
Dave Halford | 06/10/2020 10:04:05 |
2536 forum posts 24 photos | |
Steamer1915 | 06/10/2020 10:05:23 |
![]() 171 forum posts 42 photos | Pressure angle?
Steve. |
not done it yet | 06/10/2020 10:11:40 |
7517 forum posts 20 photos | HPC Gears will make one if the above doesn’t fit the bill. Likely need to sit down before asking the price. |
Clive Barker | 06/10/2020 10:51:41 |
![]() 55 forum posts 29 photos | Thank you all for your responses. Dave I don't know how I missed the imperial sizes in the HPC listing. As for pressure angle - I am going to have to get the magnifying glass out! I assume 20deg. |
Pete Rimmer | 06/10/2020 18:51:13 |
1486 forum posts 105 photos | HPC have a minimum order. I could knock one up for you Clive, if you send me the details. You might have to cut your own keyway. Is it a Myford change gear? |
JasonB | 06/10/2020 18:55:37 |
![]() 25215 forum posts 3105 photos 1 articles | No minimum with HPC, have a look at their FAQs And a Myford gear would be 14.5pa |
Bazyle | 06/10/2020 19:21:29 |
![]() 6956 forum posts 229 photos | Ok I know you may not like us to poke into youir business but do make sure you really need it. On another forum a couple of months ago a chap went to lots of trouble and expense to get a gear to cut a non-standard thread to approximate a metric thread. It turned out he actually could cut a better thread with the gears he already had. |
Pete Rimmer | 06/10/2020 19:23:19 |
1486 forum posts 105 photos | Posted by JasonB on 06/10/2020 18:55:37:
No minimum with HPC, have a look at their FAQs And a Myford gear would be 14.5pa Hmm, you're right. I checked back a few years and it's been that way a while. I must be remembering it wrong, or confusing with another supplier. |
Clive Barker | 15/10/2020 15:59:59 |
![]() 55 forum posts 29 photos | Thanks Jason & Pete for your replies. It is the idler gear for a Colchester Student Mk1 Norton Gearbox. Using a magnifying glass ruler and protractor it looks like 20deg pressure angle. The HPC off the shelf gear with a sleeve looks like the way to go. |
