Apex taps
Axel01/09/2020 10:14:19
126 forum posts
I bought bunch of taps from Reeves2000 two years ago. I do not know if this is their own brand, but they are called Apex. Worst rubbish I have ever come across!T he smaller ones break all the time, even in soft BMS and soft finger pressure. Are there any ME thread taps available from a quality brand?
Circlip01/09/2020 10:35:07
1723 forum posts
Try Tracy, good selection.
Regards Ian.
Baz01/09/2020 11:16:21
1033 forum posts
Tap and Die company, very good quality.
KWIL01/09/2020 11:23:58
3681 forum posts
70 photos
Lubrication, back off to clear flutes, guide block to hold perpendicular??
Brian H01/09/2020 12:46:12
2312 forum posts
112 photos
I'd go with the suggestion from Baz. Tap & Die products are OK.
Mike Poole01/09/2020 13:05:01
3676 forum posts
82 photos
Carbon steel taps are rather brittle and do not bend. Tapping small sizes is safer with a tapping fixture like one of the roles of the universal pillar tool, only the slightest side pressure will snap a small tap. I have one or two Apex taps and found them to be ok.
not done it yet01/09/2020 14:14:57
7517 forum posts
20 photos
First question might be :How are you using them? Tapping size of holes, tapered, second or plug taps, tapping arrangement and cutting compound can all make a difference between success and failure.
Chris Evans 601/09/2020 14:27:17
2156 forum posts
For most tapping I do especially for small sizes I drill at least 0.1mm oversize. Usually 0.2mm and mostly tap on the mill with a guide to keep vertical. Rocol or similar RTD and a squirt of tapping fluid as well. I haven't broken a tap in the last 15 or 20 years. Edit, all my taps are HSS.
Edited By Chris Evans 6 on 01/09/2020 14:28:22
