Bioler
kevin large | 30/08/2020 16:02:09 |
143 forum posts 3 photos | Hi all I would like to make a simple vertical bioler can anyone point me to where I could get some free plans And what would be the best solder to use |
Tim Stevens | 30/08/2020 16:23:17 |
![]() 1779 forum posts 1 photos | An interesting idea - using a bioler instead of the more usual type. But as usual, we might guess that you need a boiler to raise steam for a model - is that correct? Then there will be questions like 'how big' and 'what pressure', as well as 'have you done anything like this before - ie made something that could blow up in your face and take the shed roof with it?' Regards, Tim
kevin large | 30/08/2020 16:29:58 |
143 forum posts 3 photos | Hi Tim yes it is for steam I have several small steam engines ie Stuart beam etc I've made several small steam engines just simple stuff But would now like to make a bioler to run about 60 80 psi vertical about 100mm dia and about 250 high gas heated |
David Wasson | 30/08/2020 16:44:11 |
![]() 149 forum posts 43 photos | Slow down Kevin, "bioler". Let's try "boiler". |
kevin large | 30/08/2020 17:10:30 |
143 forum posts 3 photos | Woops |
David Wasson | 30/08/2020 18:09:08 |
![]() 149 forum posts 43 photos | No problem, carry on Kevin! ( if you read Tim's post, I think he was initially pulling your leg a bit) |
Thor 🇳🇴 | 30/08/2020 18:30:26 |
![]() 1766 forum posts 46 photos | Hi Kevin, There is one free plan of a vertical boiler here, might be a bit smaller than you want. You should also find some build logs here. Thor Edited By Thor on 30/08/2020 18:38:37 |
Clive Brown 1 | 30/08/2020 19:00:08 |
1050 forum posts 56 photos | Longtimes ago ME published a Tubal Cain design and construction series for a 3" vertical boiler. Very simple and satisfying to make with a central flue and 3 water tubes crossing the firebox. My gas-fired example steams at up to 80 psi and runs my Stuart Turner engine nicely. 'Fraid I can't recall the ME issues. |
David Davies 8 | 30/08/2020 19:22:33 |
![]() 202 forum posts 1 photos | Kevin Tubal Cain's 3 inch boiler is listed as a kit of parts and drawings by AJ Reeves. Possibly this is the one referred to above by Clive Brown. HTH Dave |
John Purdy | 30/08/2020 19:43:15 |
![]() 431 forum posts 252 photos | Kevin Tubal Cain's 3" test boiler was described in ME 18 Feb "77. I made one and you can see a picture of it, and the GA drawing of it in my album. It steams my ST10 quite well on only 10 PSI or so. John |
Martin Kyte | 30/08/2020 22:22:57 |
![]() 3445 forum posts 62 photos | Kennions vertical boiler kit is relatively simple to build. regards Martin |
