Switch gear for 2 speed motor
Tom Walker 117/08/2020 14:26:45
45 forum posts
6 photos
I have a Colchester Bantam, with a single speed motor. I am looking for a 2 speed motor for it, and want to be prepared, so need to find out about how to install the switching.
My manual, downloaded from a website, does not include a wiring diagram for a 2 speed motor. I also have no idea what switches I need to order.
I would be grateful if anyone can help.
Tom.
Emgee17/08/2020 15:44:24
2610 forum posts
312 photos
Tom
If you go to the link below and press the JOIN button there is copy of the wiring schematic in the parts manual, and a lot of other relevant information that you may find helpful.
Emgee
Use the following after joining
https://colchesterlathe.groups.io/g/main/files/Colchester%20Bantam/Bantam%205%C2%BD%22%20%28140mm%29%20Manual/Bantam%205%C2%BD%22%20%28140mm%29%20manual%20-%20Installation,%20Operation%20and%20Parts%20list/Bantam%20Manual%20Installation.pdf
Edited By Emgee on 17/08/2020 15:47:55
Tom Walker 118/08/2020 09:04:35
45 forum posts
6 photos
Thank you very much Emgee for your help. That is an amazing website which will give alot of information.
DC31k18/08/2020 11:00:30
1186 forum posts
11 photos
Implicit in your request is that you are seeking a three-phase two-speed motor. Are you aware that two-speed three phase motors are difficult to run on 230v three phase (i.e. you need full fat 415v 3-phase. The semi-skimmed low voltage version will not do)?
Andrew Johnston18/08/2020 12:08:58
7061 forum posts
719 photos
I believe that Tom said in another thread that he had a 3-phase supply available.
Brian Morehen18/08/2020 19:04:39
191 forum posts
11 photos
Are you looking at 2 Speed Single phase motor or 3 Phase 2 Speed Motor or Maybe a inverter drive motor .more details are required .
Bee M
Tom Walker 119/08/2020 11:10:40
45 forum posts
6 photos
Sorry Brian. I ve had a busy 2 days. My motor will be a 2 speed 3 phase motor. But I am replacing a single speed 3 phase motor, so dont have the correct wiring/switch gear for the 2 speed motor. I would like advice as to what to buy and how to connect it.
Thanks, Tom.
Tom Walker 119/08/2020 11:30:58
45 forum posts
6 photos
This is the plate off the 2 speed motor.
Tom Walker 119/08/2020 11:33:28
45 forum posts
6 photos
Although I will get my elecrician to do the wiring and connection, I would like to understand what needs doing, and also buy and mount the switches "first fix".
John Haine19/08/2020 13:03:36
5563 forum posts
322 photos
Why not just fit an inverter and have done with it?
Harry Wilkes19/08/2020 14:37:04
1613 forum posts
72 photos
I believe from a previous post Tom as got a VFD but despite a number of members suggesting he leave his VFD fitted Tom seems to want to fit the two speed motor he's got !
Brian Morehen19/08/2020 16:16:22
191 forum posts
11 photos
Hi Tom ,
I guess your motor has 6 Terminals for connections 3 for low speed and 3 for high speed Your Motor has 2 sets of windings One for Low , and one for high speed , You will need a three phase control panel that allows a complete disconnection of supply from low speed that allows the motor to stop , Before you switch to high speed ...
Your Electrician will be able to sort this out for you..
A 3 phase changeover switch may work I position for low speed and the other for high speed . Dont Switch from one to the other before the motor stops
Good Luck Brian
Tom Walker 119/08/2020 17:47:09
45 forum posts
6 photos
Thanks Brian, I dont think there will be a problem waiting for the spindle to stop before changing speeds, because the speed is chosen for the job, and not continuously changed.
The main reason for not going down the VFD route was that I want a higher chuck speed than the inverter delivers.
Emgee19/08/2020 19:56:56
2610 forum posts
312 photos
Tom
I believe you will find a pole changing start set-up is needed if you have an original type 2 speed motor, all windings are used for both speeds, similar to Dahlander circuit.
Emgee
Brian Morehen19/08/2020 21:21:50
191 forum posts
11 photos
Tom
Your motor Data plate shows 3 Phase and voltages for 3 phase , I think you will have to ask your Electrician without being able to check this motor and test , there are a few questions that raise alarm as a three phase motor that starts to run on 2 phases sounds incorrect . Once you run this motor all questions will be answered amperage loadings will all be the same for each phase and may change depending on the speed that you a running the motor free from any load .
Regards Brian
Tom Walker 119/08/2020 21:41:56
45 forum posts
6 photos
OK MG and Brian, you are making me think I need an original Colchester wiring diagram.
The 2 speed motor I have bought, its plate is the one I posted, is off a Bantam, so I know it was built for the application.
I am not good at electrics, so will pass on your comments to my electrician. Will try and dig up a wiring diagram.
Im enjoying this, its just out of my area of knowledge!
Andrew Johnston19/08/2020 21:52:16
7061 forum posts
719 photos
Brian: I don't understand your last post? In my experience running a 2-speed motor on a 3-phase supply (which Tom has) works just fine. I'm not sure where starting on 2 phases comes into the picture?
Emgee19/08/2020 22:14:38
2610 forum posts
312 photos
Tom
If you use the 2nd link I posted that takes you to the Manual showing on page 8 an electrical schematic for your electrician.
Emgee
John Reese19/08/2020 23:56:33
1071 forum posts
I found a coupe on flea bay. Here is a link.ebay.com/itm/Milling-Machine-Part-New-Forward-Reverse-Switch
I purchased one The contacts are rather small so I suspect life will be short if switched between fwd and rev as in tapping.
Alan Johnson 720/08/2020 01:59:29
127 forum posts
19 photos
Good Morning Tom,
I have a friend, who, about five years ago replaced the two speed motor with a single phase motor, and he gaave me the old motor. So, if you want a spare, pop round and pick it up! Airfares may be expensive!
From your motor nameplate photograph, you have a two pole / four pole three phase motor. The easiest solution, if you can't source a switch, is to install two contactors with electrical and mechanicaal interlocks that will prevent both contactors being energised at the same time.
Alan.
