Here is a list of all the postings Tom Walker 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Switch gear for 2 speed motor |
20/09/2020 18:30:41 |
Hi John, thank you very much for that diagram, it will be a great help when the electrician comes, hopefully early this week. Re the motor Tim, I sincerely hope I wont need yours, but its reassuring to know there is a good one available if it comes to that. Thanks for your offer. |
16/09/2020 21:48:27 |
Posted by Brian Morehen on 16/09/2020 18:01:51:
Hi Tom A three phase motor has 3 leads , connect each of your phases one to each lead and your motor will run if this runs o/k it may be running either slow or fast , which ever it is this will tell you which speed it is running at. If the direction is wrong change over two of your incoming leads to reverse rotation. al O/k St test complete disconnect your incoming supply and then reconnect to the other 3 leads your motor will either run fast or slow 2 test complete., Your Motor has two sets of win or fast .
I get that, and that is the kind of "walk him through it" instructions I need! BUT, according to the motor wiring diagram, you have to link the low speed posts together while in high speed.
Edited By Tom Walker 1 on 16/09/2020 21:49:22 Edited By Tom Walker 1 on 16/09/2020 21:50:53 |
16/09/2020 21:43:50 |
Posted by John Sykes 1 on 16/09/2020 17:14:29:
You already have the DOL. The switch you need is here: Ebay item no 202953411153 @ £36 delivered. John
Thanks John, I have one on order.
Edited By Tom Walker 1 on 16/09/2020 21:52:47 |
16/09/2020 13:38:03 |
Ah! Anyone got a spare one of Emgees switches?! |
16/09/2020 08:30:38 |
Sorry, I posted too quickly, I can see that it is Pole Change. |
16/09/2020 08:29:07 |
Just looking at Johns scan of the Brooks book. Is my motor 2 speed (pole change) or 2 speed (dual wound).? I presume from the red wiring diagram I posted, attached to my motor, that it is Pole Change, because of the linking together of A3, B3, and C3. |
15/09/2020 21:47:06 |
Thank you John, for taking the trouble. Much appreciated. Tom. |
15/09/2020 07:48:06 |
Posted by Emgee on 14/09/2020 23:33:59:
Posted by John Sykes 1 on 14/09/2020 17:04:41:
I have the Broook Motors book on Induction Motors (my father worked for them his entire career). Pg 199 show precisely the wiring which Tom posted above. It is possible to wire up a star-delta switch to perform the two speed switching. Everything else can be left alone: the switch is interposed between the output of the existing contactor and the new two-speed motor. I can post a schematic if you're interested. Hi John It would be helpful to see the Brook motors schematic for the motor wiring if you can upload it. Emgee
As Emgee says, John, it might help my cause (I need all the help I can get!). If it is possible for you to upload a diagram it would be very interesting. Thanks, Tom.
15/09/2020 07:35:56 |
Thank you very much indeed for all the above, which is very helpful. |
14/09/2020 10:19:12 |
Harvest has intervened, and my electrician has been hard pressed. So motor not wired, but it is installed. Please can I ask another question concerning the 2 speed motor wiring? Here is a diagram from the motor. Does the connection instruction for the High Speed, the lower of the two diagrams, imply that when L1, L2 and L3 are connected to A2, B2 and C2,, A3, B3 and C3 are connected together? I dont really understand how they are not connected together (for obvious reasons) in Low Speed, but are in High Speed. Does this have to be done in the switch? Thanks for guidance.
28/08/2020 17:03:03 |
Yup Brian, it is looking promising. I dont know what it is with mains electrics, its not as if I am incapable. I am good on vehicle electrics, and I installed all the conduit and cabling for my workshop as per the sparky instructions, but I have never dug deep into mains and 3 phase. Probably a good thing, I have had the odd jab from farm electrics, once bitten twice shy... I am near Market Harborough, and spend most of my time fettling vintage bikes and cars. Racing took up all my spare time, but that is a young mans game. Still doing a bit though, and rallies, hill-climbs etc. Many thanks due to all on this forum. I will continue with the posts till the lathe is going on 2 speeds. It may possibly help others. |
28/08/2020 12:13:55 |
This is the switch which is operated by the lever on the apron
28/08/2020 12:06:00 |
Well Im not sure, Dave, that I always do things for strictly logical, sensible reasons (though I am also a hypocrite because I berate the girls in my family for their non-logical thinking sometimes!). So it can be problematical when one approaches the patient and helpful forum members with a problem, and then go off on a route which most think is possibly the wrong one. It smacks of thick-headedness. All that said, I now have in my possession, a 2 speed motor, so am committed, if only to the tune of 80 quid. Emgee is kindly staying with the folly, and here are the photos of the box which may contain starter and overload. You said BD15, so we have a match. Give or take a D.
Edited By Tom Walker 1 on 28/08/2020 12:12:18 Edited By Tom Walker 1 on 28/08/2020 12:17:03 |
28/08/2020 07:48:00 |
Emgee, my lathe is up and running well on the single speed 3 phase motor. Yes the lever on the apron starts and stops the motor, and switches the direction of rotation. I will take a photo of the emergency stop button on the front, with its cover off. I think it may well be an overload, as there is an adjustable thumb wheel. Please bear with. |
27/08/2020 19:38:33 |
Emgee, first of all, thank you very much for hanging on in there with me. I thought a starter would have a green "go" button, because on the farm that is what they are like. You are saying that what I thought was just an emergency stop may also be a starter in conjunction with the switch on the apron handle. Please assume that I have a low level of understanding then halve it. I struggle to "read" the wiring schematic, because you need a level of knowledge to know what symbol means what. However, I will get there in the end because the forum is a great help. I must admit I was put on the back foot by the fact that none of the off switches seem to work. I will identify the parts of the switch as you request. I meant direction of rotation by DOR. I think I may have made that up |
27/08/2020 11:56:25 |
WRONG! The box on the back is the transformer for the light, not an isolator. I took the front off the emergency stop and cant see anything obviously disconnected. It is also the overload by the look of it. |
27/08/2020 11:34:00 |
Emgee no, it only has an emergency stop button and the suds pump switch box" on/off" on the front. Interestingly, because you asked, I checked all the switches. There is a main on/off box on the back, and the stop button on the front. The stop button doesnt work, neither do the safety switch on the gear cover, nor the switch on the foot brake! The lever on the apron starts and controls DOR with the drop rod that goes thru the chips tray to a switch which is tucked away behind the emergency stop box, on the other side of the panel. So you can see it easily from the back of the lathe, as you would expect. |
26/08/2020 13:12:15 |
So looking at the wiring diagrams I need the 2 speed switch and another motor overload for the second speed, wired between the 2 speed switch and the motor. Luckily it seems the reverse switch can be left as is, but even with the wiring diagram in front of me, because I am "wiring diagram illiterate", I dont see how the reverse switch and the 2 speed switch manage to to everything. I just need part numbers/makes for the two components. |
26/08/2020 10:42:42 |
Posted by Emgee on 23/08/2020 22:04:31:
Tom You are almost right, but not a 2 way but a 2 position switch providing High or Low speed configuration of the windings. The levers will normally provide Stop/Start also Fwd and Rev direction of spindle depending if the lever is lifted up to start or pushed down. Emgee
Emgee, my lathe has a start lever which does as you say, up to start one DOR, and down to start the other DOR
25/08/2020 09:05:47 |
Thank you Andrew. Emgee, I have cracked it, and found the files at the Colchester website. I presume that the wiring diagram in the lathe manual is the one you were referring to. |
