How much oil is needed...
Simon Barr | 14/08/2020 17:25:32 |
34 forum posts 18 photos | I have the smallest Warco mill the WM12. It's my first mill and I'm enjoying getting to grips with milling. I have a question regarding oiling of the ways that I'm hoping someone will be able to help with. Z and Y axis ways are dead easy to oil being vertical and horizontal upward facing respectively but the X axis is upside down so oiling is tricky. There are no button oilers fitted so I have been resorting to running an oily fingertip along the X axis ways in an attempt to get oil on them. This is a very messy and probably wasteful way but is working for now, I think. Is this likely to be sufficient to prevent wear? I have some oilers somewhere and have contemplated fitting some but I'm not sure if it's necessary or not and am unsure exactly where would be best to put them. Any suggestions are welcomed. Simon |
mechman48 | 14/08/2020 17:50:47 |
![]() 2947 forum posts 468 photos | Hi Simon We're all in a similar position in one form or another. There are 'one shot' lube systems on the market for most machines, Arc Euro sell one specifically for Myfords but could be used for other machines. I have a WM16 mill & I lubricate it it the awkward way; from underneath the table using a squirt oil can with a flexible spout & SAE 10-40 transmission oil, whilst moving the table along it's travel axis, works fine for me to date, it does get messy but I wipe up any excess afterwards. Horses for courses I s'pose George. |
Dave Halford | 14/08/2020 18:11:14 |
2536 forum posts 24 photos | Tooth brush and jam jar (other jars are available) |
JasonB | 14/08/2020 18:22:42 |
![]() 25215 forum posts 3105 photos 1 articles | Hopefully another toothbrush will be available too |
Simon Barr | 14/08/2020 19:10:55 |
34 forum posts 18 photos | So what I'm doing is OK then I guess. Thanks for the replies. Using a tooth brush didn't occur to me but it definitely should have as that's exactly how I oil the chain on my motorbikes. A jar of EP90 and a tooth brush. I have a small stash of old brushes so I think I'll stop using my finger and use one of them instead Simon |
Dave Halford | 14/08/2020 19:15:49 |
2536 forum posts 24 photos | Posted by JasonB on 14/08/2020 18:22:42:
Hopefully another toothbrush will be available too Think the first Paddington Bear film -----------------------------and shudder. |
John Haine | 14/08/2020 19:23:21 |
5563 forum posts 322 photos | Cotton bud. |
IanT | 14/08/2020 21:18:33 |
2147 forum posts 222 photos | Glue (or "Acid" ) brushes are cheap and very handy for spreading or applying 'oils' - be that lubrication or cutting - better than using a toothbrush (or your fingers) Regards,
IanT
Edited By IanT on 14/08/2020 21:19:10 |
Paul Lousick | 14/08/2020 23:18:51 |
2276 forum posts 801 photos | Use a good flavoured oil on the tooth brush. Some leave an awful taste in your mouth. |
ega | 15/08/2020 08:49:30 |
2805 forum posts 219 photos | Way oil is available in spray cans and might be a solution for the OP's problem. |
Paul Lousick | 15/08/2020 11:07:00 |
2276 forum posts 801 photos | Oil can with a flexible spout for those difficult locations. |
