Mike Donnerstag | 19/07/2020 23:22:27 |
![]() 231 forum posts 53 photos | I'm just learning Fusion 360 and noticed there were no British threads as standard. I found that custom threads could be added if you downloaded or created the relevant XML file. I added ME and BA threads in this way. However, I couldn't find any file for BSW and BSF threads. Does anyone have XML files for these? Many thanks, Mike |
Paul Lousick | 20/07/2020 03:55:18 |
2276 forum posts 801 photos | Hi Mike, The actual thread profile is not normaly added to a part as it increase the file size and takes longer for the computer to calculate and display. I use Solidworks, not Fusion 360 and have rarely modelled a screw thread. eg. A bolt with a thread profile would display quickly but if a large assembly has 100 of these bolts, it would slow the display time unless you have a very fast computer. (Some of my assemblies contain hundreds of individual parts and the computer would crash if the bolts had un-necessary features) If I want to display a bolt thread on a drawing, I add a surface texture to the part which looks like the thread. (similar to adding wood grain, colour, etc). Paul. |
Martin King 2 | 20/07/2020 06:59:22 |
![]() 1129 forum posts 1 photos | Hi All, Fusion360 offers the option of just showing a thread form in a drawing/model or actually modelling it in the file. It is a simple check box in the thread dialog box. Cheers, Martin |
JasonB | 20/07/2020 07:11:09 |
![]() 25215 forum posts 3105 photos 1 articles | I've got Whit for Alibre, will have a look later to see what the file type is as it was a while ago that I added all the options. Alibre will also just put the call out on the drawing and show it as double lines so you know it's threaded and not just a hole. |
JasonB | 20/07/2020 08:15:39 |
![]() 25215 forum posts 3105 photos 1 articles | Sorry mine are in an Alibre file extension .THD
Steamer1915 | 20/07/2020 10:01:56 |
![]() 171 forum posts 42 photos | I'm sure I have the Whitworth and BA threads somewhere. Give me a while and I'll try to find them. Be aware though that every time Fusion 360 updates, they seem to be thrown out and you need to re-load them.
Steve.
Steamer1915 | 20/07/2020 11:51:20 |
![]() 171 forum posts 42 photos | Mike, I have found the XML document for the BSW threads. Not sure if this works for BSF as well, the thread form being the same, just the difference in TPI. I don't know how to upload them here but I have your email address and will send you them that way, along with the BSP+Nonstandard Threads file. Not sure what's in the latter without checking. How to upload an XML document to this site? Anyone? Best regards, Steve. |
JasonB | 20/07/2020 13:19:19 |
![]() 25215 forum posts 3105 photos 1 articles | Not at the moment, either use PM or put them somewhere like Dropbox and put the link in your post. |
chris mcnicoll | 22/01/2021 05:19:56 |
43 forum posts 15 photos | Posted by Steamer1915 on 20/07/2020 11:51:20:
Mike, I have found the XML document for the BSW threads. Not sure if this works for BSF as well, the thread form being the same, just the difference in TPI. I don't know how to upload them here but I have your email address and will send you them that way, along with the BSP+Nonstandard Threads file. Not sure what's in the latter without checking. How to upload an XML document to this site? Anyone? Best regards, Steve. hi steve is it possible to get this file from you please? many thanks
chris |
Steamer1915 | 22/01/2021 09:53:46 |
![]() 171 forum posts 42 photos | Hi Chris, Could you send me a PM please? Best regards, Steve. |
chris mcnicoll | 22/01/2021 15:26:44 |
43 forum posts 15 photos | Posted by Steamer1915 on 22/01/2021 09:53:46:
Hi Chris, Could you send me a PM please? Best regards, Steve. PM sent Steve, many thanks |
Clayton Wade Read | 18/08/2021 04:58:38 |
1 forum posts | Hi, Is anyone able to send me the BSW Thread XML file? any help would be greatly appreciated Regards, Clayton |
Andy Pugh | 26/12/2021 18:34:42 |
67 forum posts 1 photos | I have created a macro / spreadsheet to create XML files for Fusion 360 threads. https://github.com/andypugh/FusionThreads There is a ready-to-use Whitworth XML there (based on mid-tolerance medium threads) To create your own, Duplicate the Whitworth tab, type in the tread data then run the macro (View->Macros to see it) It will create an XML file based on the active worksheet in the same directory as the spreadsheet file.
Edited By Andy Pugh on 26/12/2021 18:35:27 |
Bill Pudney | 26/12/2021 22:57:48 |
622 forum posts 24 photos | Are accurate thread profiles really required?? In my lifetime of being involved in producing and analysing professionally produced drawings, the only time that accurate thread profiles had to be drawn were at night school during my apprenticeship, and even then it wasn't about the thread profile, but the accuracy of the drawing. Surely this is a classic case of "want" over "need"?? Convince me I'm wrong. cheers Bill |
JasonB | 27/12/2021 07:35:59 |
![]() 25215 forum posts 3105 photos 1 articles | Bill, I'm sure Fuson can be used like Alibre in which case at the 3D modeling stage you can place a threaded hole or thread an external part. During modeling depemding on what settings you choose just be shown as a simple second line much as it would if on a 2D drawing or you can have a visual representation. At the time you come to produce the 2D working drawings you can again choose how it appears on the drawing but more importantly it will add a thread call out automatically on the drawing you don't have to try and remember if you were going to thread that hole 1/4BSF or 1/4 x 20 UNC from when you design the part some time ago. The visual is useful for things like that Kant clamp assembly I drew the other day as it is easy to see what parts are threaded but not something I would want on a 2D drawing. I'd go for the option on the left for 2D working drawings, I have the default set for it to include that M8 call out onto the drawing by itself as well as the second broken lines. It will adjust the position of the broken line to suit the selected threads minor diameter and also the length if entered all I need click at design stage is M8 coarse, Click for larger clearer image But on a 3D rendering or animation having the visual thread can make things easier to understand as well as some colour to indicate material types. Again watch on youtube for larger screen
Edited By JasonB on 27/12/2021 07:40:12 |
Bill Pudney | 27/12/2021 09:42:52 |
622 forum posts 24 photos | Thanks for that JasonB, I can see the advantage that you describe. I am clearly a luddite because I still think it's a (slightly) nice to have rather than something of much value. It's probably an age thing!! cheers Bill |
Roderick Jenkins | 27/12/2021 11:19:22 |
![]() 2376 forum posts 800 photos | Bill, A fully modelled thread is very useful for 3D printing. Although the resolution of a small printed female thread is not great, they can be cleaned up easily with a tap. In my experience, tapping a plain hole in a 3D print runs the risk of delaminating the print. Happy new year, Rod |
SillyOldDuffer | 27/12/2021 12:39:39 |
10668 forum posts 2415 photos | Posted by Bill Pudney on 27/12/2021 09:42:52:
... I am clearly a luddite because I still think it's a (slightly) nice to have rather than something of much value... As always, the value depends on what you're doing. Mostly not sensible to fully model threads because they use lots of computer resource for no benefit. Fully modelling ordinary nuts and bolts is normally daft. However, as already mentioned fully modelled threads are good for 3D-printing and realistic general assembly drawings. They can also be used to animate things like screw-jacks to check interferences and so forth as a mechanism operates across it's range. Certainly a minority interest, but definitely valuable in their place. Dave
Edited By SillyOldDuffer on 27/12/2021 12:40:10 |
Bill Pudney | 27/12/2021 19:40:25 |
622 forum posts 24 photos | I had never considered 3D printing. So now I'm convinced that it's worthwhile in some areas. It still seems like a lot of (computer) power being used to draw pretty pictures though. That's what passes for progress I suppose. cheers Bill |
