Laser DRO sensor
John Hinkley08/07/2020 15:09:25
1545 forum posts
484 photos
I have been mulling over a suggestion I first mooted in 2013! It concerned the possible use of a mouse sensor as a device for producing an output to a display for use as a DRO for lathes, mills and the like. There have been a number of threads lately regarding the fitment of scales to, particularly, lathe cross slides and how they might restrict the movement of them and also interact with the chuck and/or tailstock. That set me off thinking, again. Always dangerous, but having a brief interlude in the metal-mangling, I thought - why not?
So I took an old mouse to pieces and had a look at the innards:
Not a laser mouse, but an LED one. I don't have one of the former. The rectangle indicates where I reckon the business end of the positioning electrickery is. Research has lead me to the conclusion that a laser sensor can detect movement changes of as little as 1 to 2 microns, better than my DRO glass scales, at 5µm. I therefore thought that if the sensor could be mounted in a suitable housing and secured to the cross slide, reading against an adjacent fixed part of the saddle, would it not be possible to utilise the bluetooth capabilities of a wireless mouse to communicate the output to a program running on a computer, tablet or phone in much the same way as Yury has done for the TouchDRO system? See Here.
Regrettably, I don't have the knowhow to implement the idea and write the necessary code to interpret the quadrature output into a meaningful display.
As we are in the tea room, feel free to discuss the merits or otherwise of this proposal. I have, at least, made a preliminary drawing of the sensor housing which I suggest could be 3D printed. It would need a cut-down version of the pcb designing, but I don't think that is beyond the wit of some of you on here.
housing
The overall size of this would be in the region of 20mm x 30mm x 90mm long (plus mounting lugs).
What does the panel think?
Frances IoM08/07/2020 16:09:48
1395 forum posts
30 photos
there is an article by Mark Noel some years ago along the same lines (he never lets a good bit of amenity centre throwout go to waste!) - think it was in MEW - he looked at how linear and repeatable were the measurements.
The mechanism used to find X + Y movement is to find the shift between samples of the pattern seen by the small camera chip - dim memories of 16 by 16 2D FFTs ring a bell as cross correlation of the 2 images is required. ETA I think it is actually done by lookup table as the small image is thresholded against average of the 256pels to give a 16x16 array of 0s and 1s then this 8bit value is applied as the lower 8bits with the previous 8bits as the upper 8bits to a 64k memory programmed to provide the correct X + Y shifts
Edited By Frances IoM on 08/07/2020 16:32:53
DC31k08/07/2020 16:27:56
1186 forum posts
11 photos
Have a search on 'ADNS 9800 arduino' for many ideas and working code.
John Hinkley08/07/2020 17:53:42
1545 forum posts
484 photos
Frances and DC31k,
Thanks for the info and links. Looks like I've got some reading to do!
Ady108/07/2020 18:08:07
6137 forum posts
893 photos
Had a look at stuff a couple of years ago but was never sure about the accuracy
Deffo the future though, once someone makes one, 0.1mm would do for most of us
Edited By Ady1 on 08/07/2020 18:10:15
Frances IoM08/07/2020 23:04:42
1395 forum posts
30 photos
Found the ref to Mark Noel's article - MEW March 2014 pp19-21 - he considers the scales that are needed that are needed - possibly the 1st such article ?
John Hinkley09/07/2020 08:04:05
1545 forum posts
484 photos
Frances,
Just had a quick look at Mark's article and that is the sort of thinking that I proposed on this very forum the year before. Technology has moved on since then and certainly laser displacement measurement can be in the region of 2000 cpi. I brought the subject up again in case someone wanted pick it up and run with it. Like I said, I don't have the expertise to design and fabricate a suitable pcb, nor, quite honestly, the inclination, at the moment to do so.
This is, after all, the tea room, so I'm inviting discussion. I do, however, believe that, if it can be done, there could be a market for small, cheap to produce and easily mounted units that aren't nanometre accurate, but satisfactory for hobby use. I have seen commercially available wired systems on the 'net but at "price on application". That suggests to me that they are in RR territory.
KWIL09/07/2020 09:45:30
3681 forum posts
70 photos
JH. Where on the saddle would you mount your box and what surface are you proposing should be the target for reading the movement?
John Haine09/07/2020 09:53:51
5563 forum posts
322 photos
John, I'm not sure what units you have seen that are "PoA" and in RR territory? Certainly the M-DRO magnetic units for example are relatively affordable and have a resolution of 5 microns, accuracy must be of the order of hundredths of mm. From some of the postings here there are cheaper mag scales around too, as well as the capacitive ones.
I've thought about this approach (in fact I filed a patent on it in 1999), and I know that Heidenhain did some research on the method too. One of the issues with the sensors is that they get their calibration from the accuracy of the camera chip patterning and optical system magnification, neither of which are that well controlled. For their intended application high accuracy and repeatability isn't needed. From what I recall of the "professional metrology" research it was concluded that it would be necessary to have a "scale" on the surface being measured, even if it was just a line etched every mm or so, so not a great improvement on other approaches.
Michael Gilligan09/07/2020 09:57:44
23121 forum posts
1360 photos
Posted by KWIL on 09/07/2020 09:45:30:
... what surface are you proposing should be the target for reading the movement?
The ‘camera-based’ mice don’t need a target per se ... They compare consecutive images of whatever surface they are seeing ... blank paper, cast iron, whatever [anything with more texture than an optically smooth surface]
John Hinkley09/07/2020 10:24:37
1545 forum posts
484 photos
John Haine,
I think this was the site I had a quick look at which gave rise to my PoA and RR comment - but I can't be sure because I didn't keep a record of it. Laser sensors
As for cost - I just thought that you can pick up an LED mouse for a fiver and a laser one for a bit more. How much a pcb would cost, I've no idea, but people do it in their garden sheds, so it must be doable for not a lot. A bit of programming for the display on a tablet or phone and away you go! Easy, when you say it quickly and haven't the faintest idea what's involved!
Michael G. is quite right. I envisaged the camera to "look" at the upper face of the saddle, for example. A strip of metal along the bed of the lathe at the rear would perform the same function. No "pattern" required, or so I understand.
KWIL09/07/2020 10:25:26
3681 forum posts
70 photos
Machine DRO Magnetic, Resolution 5 micron, Accuracy +/- 15 micron, so you are somewhere within a band 1.2 thou " wide.
Michael Gilligan09/07/2020 10:36:31
23121 forum posts
1360 photos
Posted by John Hinkley on 09/07/2020 10:24:37:
The Wikipedia page gives a useful overview: **LINK**
https://en.wikipedia.org/wiki/Optical_mouse
... but I’m sure I have a good article tucked-away somewhere
I may be back later
... and I am back
http://tim.cexx.org/?p=613
Edited By Michael Gilligan on 09/07/2020 11:06:00
KWIL09/07/2020 11:29:00
3681 forum posts
70 photos
John in first posting mentioned interference with tailstock.
Photo shows minimal interference on a Myford S7 using a commercial (Newall) product.
Early Myford S7 DRO
Ian P09/07/2020 11:46:27
2747 forum posts
123 photos
I know its only my opinion but that does not look like 'minimal' interference with the tailstock, it also looks extremely vulnerable by being bumped into by the tailstock.
At a guess it looks like 30mm or so of lost tailstock travel towards the carriage. I have a much larger lathe and the magnetic scale mounted in the same place as yours only adds 10mm to the carriage width. and its more or less solid ali extrusion so does not mind being hit by a heavy tailstock.
Ian P
KWIL09/07/2020 11:56:59
3681 forum posts
70 photos
20mm to be precise, not much when you have 95mm travel on tailstock even if you are touching , a buffer below the bed level prevents collisions.
Has not caused any difficulties in actual use. If you used a glued/screwed on magnetic strip you would get let less loss of travel. What was the make you used?
I used a similar approach on my M300 Harrison.
Edited By KWIL on 09/07/2020 11:59:49
John Haine09/07/2020 12:12:15
5563 forum posts
322 photos
John, thanks for that link - those laser sensors use a different principle and are in a different league from the "mouse" type sensors, hence the price. In the "laser mice" I think the laser is used as a more collimated and brighter illumination than the more common LED to getter better precision (and probably speed) - I don't think they really rely on the specific "laser" aspects such as coherence.
I'm not saying that the mouse type approach doesn't have merit, it's just that they don't inherently have tremendous accuracy and will either need a calibrated scale to look at or need individual calibration. In either case it complicates the signal processing which is done in a ready-programmed DSP on-chip.
I believe the magnetic scales (such as the M-DRO ones) have a fairly simple Hall effect sensor to read the periodic magnetic field imprinted on the "scale" - it's still a single chip reader. One of its advantages is that the scale-reader distance is pretty non critical - M-DRO quote 0.1 - 1 mm IIRC - whereas the mouse type will need its "microscope" fairly accurately focused so distance will be critical (Michael can advise I think). So I think there are good reasons why all the medium accuracy DROs haven't just adopted mouse sensors wholesale. Also when you look at the mag sensors they are well packaged for immunity from swarf and suds etc, and the reading surface appears to be an aluminium plate. A mouse type has to have an optical aperture and its lens will be prone to getting mucky and scratched.
Still very interesting devices and I'm sure they have other applications.
Ian P09/07/2020 12:13:28
2747 forum posts
123 photos
The scale is the magnetic one from Machine DRO
Tapped holes filled with button head screws came with the lathe (Harrison M250) I assume they are not original
Ian P
KWIL09/07/2020 12:31:16
3681 forum posts
70 photos
I lost 15mm on the M300 but kept the dovetail edge of the cross slide.Highland/Black5 Main Cylinder
Ian P09/07/2020 12:56:40
2747 forum posts
123 photos
I didn't know the M300 had a dovetailed edge, are there some accessories that use it?
That Newall installation looks good.
I see your cross slide also has tapped holes, the ones on my M250 seem to be in mostly random positions and none really line up with counterbored holes in the (still unused) tee slotted milling table that came with the lathe.
Ian P
