Unknown Changewheels
Martin Cargill05/07/2020 14:29:29
203 forum posts
I recently bought a couple of boxes of machine "junk". In amongst all of the bits and pieces appear to be two sets of lathe gear wheels. They are of a strange design and have two pins that provide drive. Anyone have any idea of what machine they might belong to?
Martin
not done it yet05/07/2020 14:37:45
7517 forum posts
20 photos
DP, axle size, pin size and radius might be good for identification or ‘removal from the equation’.
Pete Rimmer05/07/2020 15:10:10
1486 forum posts
105 photos
Posted by Martin Cargill on 05/07/2020 14:29:29:
Martin
They are quite possibly Drummond gears. Quite popular though I never understood why.
Howard Lewis05/07/2020 16:21:55
7227 forum posts
21 photos
If you can tell: Bore size, Outside diameter - inches and mm, number of teeth, and thickness, it will help.
At the moment everyone is wondering how long is your particular piece of string!.
These details will allow the DP of the gears to be calculated.
Knowing the DP, the bore and the thickness (Tooth width and centre/hub thickness ), others on here may be able to make a better estimate of what machine the gears may suit.
Martin Cargill05/07/2020 16:41:18
203 forum posts
Just measured one of them, all measurements are imperial
3.36 diameter
45 teeth
0.625 bore
two pin holes 0.18 and 0.2 diameter
inside to inside pin holes 0.77
outside to outside pin holes 1.15
didn't measure the thickness but I would guess at 0.5
Martin
David George 105/07/2020 16:55:13
2110 forum posts
565 photos
I am almost sure that they are Drummond gears. They are probably a missing set or two. Well sort after by people who buy a lathe with non of only some gears.
DAVID
Pete Rimmer05/07/2020 16:58:46
1486 forum posts
105 photos
Sound like Drummond. I think one hole is straight, the other tapered.
Anyway, they should sell well.
DC31k05/07/2020 17:05:04
1186 forum posts
11 photos
Posted by Pete Rimmer on 05/07/2020 15:10:10:
Because they are 14DP and this size is difficult to find and difficult to find good quality cutters for making them. Used on Chipmaster, early Colchester (maybe Student & Master), Harrison L5 and derivatives (e.g. 140).
Howard Lewis05/07/2020 17:07:12
7227 forum posts
21 photos
The DP calculates as 13.98, so 14 DP. So with two driving pins they are certainly not for a Myford.
Don't know the Drummond, but sounds a distinct possibility
not done it yet05/07/2020 18:07:37
7517 forum posts
20 photos
Raglan also used 14DP and 5/8” bore. If original, I would expect them to have part numbers embossed on the casting.
Martin Cargill07/07/2020 21:20:33
203 forum posts
Thank you for all of your thoughts and information gentlemen.
I've been out in the workshop tonight giving the gears a clean up to see what was there. There are four new ( still in bags) 3/4" wide gears that are marked L5 so I assume these are Harrison. There are twelve gears with the double pin holes that I assume are Drummond and two gears without pin holes that I'm guessing are Raglan these are all 1/2" wide. All have the same 14 DP.
Martin
Nigel Graham 207/07/2020 23:40:03
3293 forum posts
112 photos
I would concur with that L5 marking probably indicating "Harrison" as I own an L5.
There seem still to be a lot of Drummond lathes about, so finding a new home for those wheels should not be too difficult.
I'd be interested in the "L5" ones subject to fuller cross-identifying, if they don't suit any of your machines, as the set with my lathe seems incomplete.
