Dave T | 24/06/2020 21:35:31 |
69 forum posts 1 photos | Has anyone got any recommendations for the above. I need to make up a gap of approx 0,3 and I've got no suitable shim - I would also like it to be permanent. See various stuff on YouTube but nothing seems to be available in the UK Cheers Dave |
Keith Long | 24/06/2020 21:49:30 |
883 forum posts 11 photos | Some of the metal filled epoxies by the likes of Devcon sound to be what you're after- but they won't be cheap. |
Former Member | 24/06/2020 21:53:57 |
[This posting has been removed] | |
Michael Gilligan | 24/06/2020 21:58:05 |
![]() 23121 forum posts 1360 photos | I have successfully used Loctite 638 as a shim ... Just be sure to coat any fasteners with a release agent if you might want to dissemble things later. [ It has quite low ‘peel strength’ so the flat surfaces are no real problem. ] MichaelG. |
Dave T | 24/06/2020 22:24:28 |
69 forum posts 1 photos | Thanks Guys |
Mark Rand | 24/06/2020 23:02:43 |
1505 forum posts 56 photos | Assuming we're talking about 0.3mm, then get a few sheets of plastic shim from cromwell.co.uk or mscdirect .co.uk.
You could get brass or steel shim stock to do the job, but the plastic works wuite well and is available in thin sheets.
Liquid shim concepts might appear to be good. but how do you tighten the parts down to them? |
Michael Gilligan | 24/06/2020 23:40:31 |
![]() 23121 forum posts 1360 photos | Posted by Mark Rand on 24/06/2020 23:02:43:
[…] Liquid shim concepts might appear to be good. but how do you tighten the parts down to them? . I know one shouldn’t ... but: I assumed that Dave had [or would contrive] something which made 3-point contact, and wanted to fill the remaining gaps with his ‘liquid shim’ MichaelG. |
duncan webster | 24/06/2020 23:57:45 |
5307 forum posts 83 photos | cut up food or drinks cans make good shims, and free. |
John Haine | 25/06/2020 06:45:31 |
5563 forum posts 322 photos | Garden suppliers have strips of ali about 10 x 40 x 0.5 mm. Made for greenhouse glazing, to make those little S-clips between glass sheets. Invaluable for quick shims, packing etc in the workshop. |
Bo'sun | 25/06/2020 08:28:53 |
754 forum posts 2 photos | Aluminium beer cans work well as shims and "work protectors", but don't use the stuff too near the bottom of the can, as it can be slightly thicker due to the manufacturing process (impact extrusion I think). To be sure, get the mic out! The best bit is, you have to drink more beer. |
