Will Carbide work?
David Davies 8 | 13/06/2020 23:19:27 |
![]() 202 forum posts 1 photos | I have some blades which are too long for my power hacksaw. It crossed my mind that a carbide drill could produce a new mounting hole at the correct centres. Has anyone tried this and what was the result? thanks Dave |
peak4 | 14/06/2020 01:51:24 |
![]() 2207 forum posts 210 photos | I'm sure you could use a conventional solid carbide bit, but they are rather expensive.
pgk pgk | 14/06/2020 07:04:58 |
2661 forum posts 294 photos | I've not tried it but diamond drills for a dremel type tool are cheap enough - perhaps in a bath of coolant. But you need to add the matching hose, foot switch and make up fittings for a workshop compressor and pressure bottle. If feeling wealthy you can even go for something like this + the handpiece and home compressor.Link pgk Edited By pgk pgk on 14/06/2020 07:10:51 |
JasonB | 14/06/2020 07:05:31 |
![]() 25215 forum posts 3105 photos 1 articles | Is the blade actually HSS all the way through or Bi-metal in which case it should be easier to drill the softer spine. |
David Davies 8 | 14/06/2020 07:06:33 |
![]() 202 forum posts 1 photos | Hi Bill Thanks for the details of how you go about the job! Cheers Dave
David Davies 8 | 14/06/2020 07:09:37 |
![]() 202 forum posts 1 photos | Jason the blade is ''all hard'' not 'bi-metal' so I don't have that option. Cheers Dave |
David Davies 8 | 14/06/2020 07:14:19 |
![]() 202 forum posts 1 photos | PGK Thanks for the alternative method. It did occur to me that spark erosion could also be used. If my memory serves me correctly machines to do this have been described in ME & MEW in the past. Cheers Dave |
not done it yet | 14/06/2020 08:02:57 |
7517 forum posts 20 photos | Simply softening the area to be drilled might well suffice? I doubt they are HSS. |
Pete Rimmer | 14/06/2020 08:09:15 |
1486 forum posts 105 photos | I drilled one with a broken carbide end mill. I just ground a small spade end on it and pushed it through in the drill press. |
colin brannigan | 14/06/2020 08:13:04 |
125 forum posts 29 photos | Drilled an Eclipse all hard blade yesterday, used a 3.4 carbide drill but first heated the area to be drilled to cherry and let it cool, then I no problem. Colin |
Michael Gilligan | 14/06/2020 08:21:47 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 14/06/2020 08:02:57: . […] I doubt they are HSS. . Why ? MichaelG. |
Mike Poole | 14/06/2020 08:46:57 |
![]() 3676 forum posts 82 photos | It is unlikely that HSS will soften by just getting it to red heat and letting it cool, you may get lucky though. Mike |
Nigel McBurney 1 | 14/06/2020 09:08:03 |
![]() 1101 forum posts 3 photos | I also convert HSS hacksaw blades for my Rapidor,Requiring 14 inch blades,I found at one time there were numbers of 17 inch blades on the second hand market as there few customer needing 17 inch blades,so deals could be done buying job lots,I shortened the blade then drilled the blade ,I used drills with brazed carbide tips from the chap who went around the steam fairs selling these drills ,his demo of perforating large old mt drills and old files was impressive,he was not amused when I asked why would you want a hole in a file,was it for hanging the file on a nail,he did not have a sense of humour. |
