DRO kit for Myford S7 from Machine DRO
Die Hardenedbedway11/06/2020 06:45:00
44 forum posts
40 photos
Hi chaps
Im thinking of buying the DRO set from Machine DRO for my super 7.
Does anyone have any experiences with fitting this kit specific to the 7 ?
I would be looking at the 'no drill' version as clearance at the back of my lathe is minimal. Ive had a quick shufty over Youtube and it looks quite straightforward.
I did the tail stock yesterday doing the much used set of old calipers method. It works very well !
Carl
tailstock mod
Edited By Die Hardenedbedway on 11/06/2020 06:46:55
Edited By Die Hardenedbedway on 11/06/2020 06:47:39
Edited By Die Hardenedbedway on 11/06/2020 06:49:04
JasonB11/06/2020 07:08:17
I think there was an article about fitting the kit featured in MEW or maybe ME about a year ago
colin brannigan11/06/2020 09:37:51
125 forum posts
29 photos
I fitted a bolt on kit to my 7 two years ago and it was plain sailing and it has worked perfectly ever since.
Colin
Harry Wilkes11/06/2020 09:40:20
1613 forum posts
72 photos
Hi Carl
I fitted one two years back had no problems at all the included instructions were stop on, I choose to go with the embedded mag strip on the cross slide which a friend machined for me .More than happy with setup
H
Die Hardenedbedway11/06/2020 10:06:54
44 forum posts
40 photos
Cheers folks. I just took the plunge and purchased one, should be here tomoz .laugh
Edited By Die Hardenedbedway on 11/06/2020 10:07:06
Fowlers Fury11/06/2020 11:23:06
446 forum posts
88 photos
As Jason recollects above, there were articles describing in full the installation of the M-DRO kit on a S7.
The first article appeared in MEW No. 267, May 2018.
The whole process is quite straightforward but the articles do point out a few potential problems.
Harry Wilkes11/06/2020 16:15:29
1613 forum posts
72 photos
There's one or two decent youtube videos on the installing
H
Die Hardenedbedway16/06/2020 07:00:57
44 forum posts
40 photos
So the DRO came and was installed without any problems.
The DRO when first turned on fluctuated wildly on the X until i realised it was the coolant stalk vibrating and transfering those vibrations to the reader. I had set the coolant on the DRO frame as it put it right out of the way. Once moved, bingo.
Only thing I added was a simple swarf shield to the X reader
So far so good
Carl
Cornish Jack16/06/2020 09:38:31
1228 forum posts
172 photos
Hmm ... interesting. Different folks, different strokes!
I'm in the process of fitting a 2 axis M-Dro set (bought nearly 2 years ago!) to a D-W mill. Getting there, gradually, but had it not been for the Youtube videos published by ProDro, I would have given up before starting! The supplied 'instructions'- 5 booklets are printed at a print size suitable for magnifying glasses. The specific items feature at the very end of one general description booklet with nothing to guide you there. The only video Allendale publish is less than helpful.
The ProDro videos, while produced in a form suitable for children, cover all the basics in a way that makes sense and are tranlatable to any equivalent product. It would appear, also, that their kits are provided with accessories which are actually of use, as against the bright, shiny, 'don't fit anything here' bits which are included with the M Dro package.
If, and it's a big 'if', the kit is fitted and (more importantly) works, I shall be relieved, surprised and grateful to other than the kit providers.
rgds
Bill
PS - I should add, in fairness, that I have no engineering skills background, so the above is from the perspective of a complete beginner.
Robert Butler16/06/2020 17:25:22
511 forum posts
6 photos
I have recently fitted my RF 45 milling machine with a Z axis DRO, having previously fitted the X & Y axis using components supplied by Machine DRO including the 3 axis console. The X & Y axis was fitted using the cast alloy brackets and other fixings and adaptors.
The Z axis was fitted to the front of the gearbox using two alloy brackets I made and fitted to the top and bottom of the gearbox. Two 8mm linear bearings were fitted to the brackets to support an 8mm guide rod to which the encoder was fitted using an alloy bracket I made. The magnetic strip was fitted to the profiled strip supplied by Machine DRO and secured between the top and bottom brackets using alloy angle. The 8mm support rod was attached to the quill shoe using a folded steel and alloy bracket I machined to fit. Provision for minor adjustment and alignment was provided and everything fitted together nicely and the quill returns sharply when in drill mode.
It looks workman like and not cobbled together and works.
One has to bear in mind we are fitting DRO's to machines which were not designed with this in mind and for Machine DRO to supply custom brackets to allow fitment to the massive range of machines we use (lathes or mills) would be out on price grounds. Before purchase it is a good idea to look see how someone else has done it and usually with the supplied brackets. Robert Butler
Cornish Jack16/06/2020 17:41:41
1228 forum posts
172 photos
Robert - your points are well made - certainly regarding not catering for specific machines. However, the bits provided in my set do not fit each other, never mind the intended machine. Allendale are at liberty to make their own decisions as to what they include in their offerings. I would suggest, however that they could learn valuable lessons from viewing their American competitors.
rgds
Bill
Robert Butler16/06/2020 18:11:27
511 forum posts
6 photos
Dear Bill, I'm not sure the brackets are supposed to fit together, the commonality is restricted to hole centres for the encoder, the rest is an intelligence test to enable the DRO to be fitted. I spent ages on the web and posted enquiries on this forum before designing my own fitment. I think the way forward is to see how someone else has done it and work around that. I have a positive surplus of unused brackets supplied with the X, Y and Z axis.
Robert
Machine-DRO16/06/2020 18:24:23
32 forum posts
25 photos
Hi Bill,
Thank you for buying one of our systems, you mentioned you purchased the system around 2 years ago, A lot has changed in that time we have invested in multiple Alu extrusion tool's over the last couple of years and continually adding to our hardware selection to try and cater for as many different machines as possible.
If you have any specific questions please send me images of where you are at on your install to my email below and I will discuss with our engineers – please include your postcode of where we shipped the system to so we can look up what DRO system you have
Carl - your Myford install looks great! Would love to use those images (and any others you can send me) on our social media?
Alan Ward
Alan@allendale-group.co.uk
Die Hardenedbedway16/06/2020 18:46:15
44 forum posts
40 photos
I cant vouch for other machines but the kit supplied for my Myford went together easy enough. I also found the instructions well presented and easy to follow
Alan, pinged over an email yes
Machine-DRO17/06/2020 08:53:18
32 forum posts
25 photos
"Alan, pinged over an email yes"
Received - much appreciated!
Cornish Jack17/06/2020 09:26:32
1228 forum posts
172 photos
Alan - thank you for your kind offer of assistance and the reassuring news that things have changed. The item is, after all, a D-I-Y kit, so one shouild expect problems. My main gripe is the lack of useful, publicly available, general advice vis-a-vis your American competitors. I would think that the web would be the prospective installer's first port of call for guidance and your present offering explains the principles but little else. It is proving to be a good exercise in ingenuity but, at 85, simplicity rules!smiley I shall continue the battle and, if successful, will post (carefully edited) photosblush
If no success, I shall retreat to basket weaving or other country pursuitsembarrassed
rgds
Bill
ega17/06/2020 23:12:02
2805 forum posts
219 photos
Cornish Jack:
Shortly before a relative of mine retired from industry his employers sent him on a basket weaving course; you seem to be doing rather better!
Steviegtr17/06/2020 23:22:56
2668 forum posts
352 photos
There is a video somewhere on youtube where the guy fitted one of the readers inside the cross slide on the Super 7 . Instead of on the outside which caused problems of covering the Gib adjusters. I have the M-Dro fitted to the Tom Senior & they are superb. I will at some point do the S7 too. A job for later. Good luck with the project.
Steve.
Michael Gilligan18/06/2020 07:52:05
23121 forum posts
1360 photos
Posted by Cornish Jack on 16/06/2020 09:38:31:
I see that you have been offered direct support by Alan Ward
... which is very impressive ‘after sales’ service.
But I must thank you for mention of the American videos, which I have bookmarked [*] for future reference:
https://www.dropros.com/Digital_Readout_DRO_Installation.htm
[*] assuming DRO PROS to be the supplier
Steviegtr18/06/2020 19:38:20
2668 forum posts
352 photos
This is the video of jan sverre fitting the DRO reader within the cross slide.
Super 7 DRO
Steve.
