ER collet adapter
Redpiperbob23/05/2020 11:03:36
92 forum posts
41 photos
Hi there I thought this information might be useful to others.
I recently bought an ER20 collet adapter for my Myford Super 7 lathe from RDG Tools. The box contains a threaded adapter for the lathe mandrill, a collet body and a collet nut.
What you are supposed to do is screw the adapter to the lathe mandrill then turn down the boss of the adapter to match the collet body (I also put a small relieve at the base of the register). I then screwed the body to the adapter and measured the run out.
I was getting 12 thou runout. I took the collet body off and measured the register it had less than half a thou runout.
I then refitted the body but did not fit the screws supplied with the kit. No runout. I then tightened the screws (carefully) and I got the 12 thou runout again. I then got three screws from my stock and fitted them, no runout. I then looked at the screws that came with the kit and noticed that the heads were not parallel with the threads. I throw them out. Job done and now less than .5 of a thou runout.
I just thought this maybe useful to someone else.
Bob
bernard towers23/05/2020 11:32:06
1221 forum posts
161 photos
Just goes to show you get what you pay for even in fasteners. I machine a lot of stainless socket heads for HD’s as in the supplied state the heads can be up to 20 thou eccentric!! It would never have occurred if they had supplied Unbrako’s.
Journeyman23/05/2020 12:01:41
1257 forum posts
264 photos
Glad you got the problem sorted. Hope the "Mandrill" didn't get too stroppy:-
They tend to get a bit grumpy cheeky. On the other hand a mandrel is usually OK with being used to support a job on the lathe or being hammered on! The lathe spindle on the other hand does not appreciate being used to form sheet metal but the spindle nose is quite alright about having chucks screwed to it.
( Apologies in advance for any distressed feelings but couldn't miss the photo opportunity! )
Redpiperbob23/05/2020 12:14:16
92 forum posts
41 photos
Damn Microsoft spell checkerangry
Bob
old mart23/05/2020 14:00:59
4655 forum posts
304 photos
If somebody posts a picture of the other side of the mandrill, it will be just as colourful. devil
Leaving a bit of play in the register and the screw holes gives you the option of getting everything running perfectly, even if one of the collets is less than perfect. With an eccentric collet, you would have to re align every time it was used as there is no way of indexing the collets in the holder.
AdrianR23/05/2020 17:17:59
613 forum posts
39 photos
Possibly as colourful as Bob's language when he found the problem wink
Adrian
Howard Lewis23/05/2020 17:22:49
7227 forum posts
21 photos
That's what happens when you start to monkey about with things!
CHARLES lipscombe24/05/2020 05:28:09
119 forum posts
8 photos
A bit off-topic but tip I picked up from another post - use a Stevenson's collet block mounted in a 4-jaw chuck. The amount of time and trouble this idea has saved me is incredible. It is also a lot cheaper than some of the alternative collet holding devices out there
Chas
Redpiperbob24/05/2020 07:45:59
92 forum posts
41 photos
Hi Chas thats what I have been doing up until this purchase.
Bob
Michael Gilligan24/05/2020 08:35:21
23121 forum posts
1360 photos
Posted by Redpiperbob on 23/05/2020 11:03:36:
Bob
Thanks, Bob ... It tells us a lot yes
but I’m not going to labour the point.
Kiwi Bloke24/05/2020 10:15:55
912 forum posts
Perhaps I'm being a bit thick, and have missed something important, but I would expect this set to be designed so that the collet body is kept in radial alignment by a register on the adaptor. I'd expect the user to have to turn the register's diameter down to size, and also to face the adaptor. Then, surely, even 'wobbly' screws - if they fit the holes - will not derange alignment.
Redpiperbob24/05/2020 10:32:31
92 forum posts
41 photos
well they pulled mine off
Kiwi Bloke24/05/2020 10:43:45
912 forum posts
I'm not doubting your observation, but I'm struggling to understand how. [I like to understand things - it's a failing...] The supply of obviously defective screws with the kit would raise my suspicions to danger level, and I'd be going all over the thing with an impressive array of metrology gear. Or wondering whether to return the thing...
Edited By Kiwi Bloke on 24/05/2020 10:47:45
