Tony Martyr | 21/05/2020 16:09:47 |
![]() 226 forum posts 45 photos | I need to temporally attach two thin Bronze flanges to a casting's face in order to drill through 10BA holes on a 15mm PCD all mounted on a dividing table. What loctite would you use? there will be little lateral force applied during drilling but it is essential for no movement to take place and de-mounting causes no distortion or surface damage. In a previous life I used to glue thin brass sheets to a face-plate when turning the knife edges on windage baffles, then release them with a hot-air gun - but I can't remember what grade of loctite we used. Tony |
Former Member | 21/05/2020 16:17:05 |
[This posting has been removed] | |
Andrew Tinsley | 21/05/2020 16:24:52 |
1817 forum posts 2 photos | I use natural resin Just put some on one component, heat lightly (hot air gun works a treat) until a running liquid and place other component on top. You will not get the two apart until it is reheated. Double sided tape works too, but it isn't infallible, as I know to my cost on one rare occasion! Andrew. |
Clive Brown 1 | 21/05/2020 16:38:54 |
1050 forum posts 56 photos | I keep a small bottle of cyanoacrylate superglue in the workshop for quick attachment of small items to spot through for hole positioning. Works in seconds. Often easier than a clamp. A quick tap usually separates the items. If not, then a bit of heat helps. Have used double sided tape as well. take your pick. |
not done it yet | 21/05/2020 16:52:35 |
7517 forum posts 20 photos | Too micro-sized for me but on a macro scale I don’t think I would do it that way. I would drill one of the two parts and then affix one piece to the other to spot and drill one fixing hole. Secure that fixing and then drill through the other holes adding more fixings as I went along. And using something to centre the flange while securing it, if it has to fit exactly. I’m likely way off beam, but just my thoughts. |
Michael Gilligan | 21/05/2020 19:33:12 |
![]() 23121 forum posts 1360 photos | Posted by Andrew Tinsley on 21/05/2020 16:24:52:
I use natural resin Just put some on one component, heat lightly (hot air gun works a treat) until a running liquid and place other component on top. You will not get the two apart until it is reheated. Double sided tape works too, but it isn't infallible, as I know to my cost on one rare occasion! Andrew. . I agree with Andrew ... Shellac should work fine Incidentally: I used some heavy-duty double-sided tape recently, and nearly lost the workpiece. I applied a few drops of PlusGas as a lubricant when milling some rather chewy Aluminium alloy: The tape lost all adhesion !! MichaelG.
John Haine | 21/05/2020 19:43:25 |
5563 forum posts 322 photos | Just use superglue? |
Jim Nic | 21/05/2020 20:21:09 |
![]() 406 forum posts 235 photos | Although it may well work, I don't think that Loctite is intended for this kind of application, more for shafts in bores. I too keep a bottle of cyanoacrylate in the workshop for just this kind of job. I find that it will stick within a short space of time, especially if your fingers get in the equation with the parts you are fixing, but the bond is better if you can leave it for an hour or so. As with all adhesives cleanliness is a good thing. To unstick it moderate heat works well and to avoid distortion I find that dropping the glued assembly in hot water usually does the trick. In the case described in the OP's question I would heat the casting with a hot air gun until the flanges fell off. Jim Edited By Jim Nic on 21/05/2020 20:21:27 |
Michael Gilligan | 21/05/2020 21:23:02 |
![]() 23121 forum posts 1360 photos | Posted by Jim Nic on 21/05/2020 20:21:09:
Although it may well work, I don't think that Loctite is intended for this kind of application, more for shafts in bores. I too keep a bottle of cyanoacrylate in the workshop for just this kind of job. […] . Unfortunately, Jim ... under Henkel ‘Loctite’ has become a brand, rather than a particular type of product, so the point is moot [ An issue regarded as potentially debatable, but no longer practically applicable.] MichaelG. .
https://www.loctiteproducts.com/en/products/fix/super-glue.html Edited By Michael Gilligan on 21/05/2020 21:23:27 |
vic francis | 21/05/2020 21:49:01 |
125 forum posts 21 photos | Posted by Barrie Lever on 21/05/2020 16:17:05:
No Loctite but good quality double sided tape. Once you holes are drilled slosh acetone over the strips and eventually the adhesive will melt. Done it lots of times. B. Yes its a good method and used it myself on acrylic sheets ect however the quality is variable... cheap stuff glue goes bungey and hard to remove and needs solvent/ brasso works well!; the red translucent expensive stuff works great, and leaves no glue film behind... i used used to soak in warm soapy water over night and the sheets prised apart easliy... super glue is good for small parts ; found that clamping while gluing works better; no idea why but less failed joints! good luck! |
Gary Wooding | 22/05/2020 09:48:56 |
1074 forum posts 290 photos | +1 for superglue. I recently made a pair of 5mm square cushion shaped gold earrings. Filing the cushion curves was easy, but holding the little squares wasn't, until I superglued them to end of a shaped wooden dowel. It worked fine, and removal was easy with a little heat. |
