Steven Kane | 06/05/2020 15:19:10 |
4 forum posts | Where can I get new gib strips for my Myford ML 4. , |
Michael Gilligan | 06/05/2020 23:54:21 |
![]() 23121 forum posts 1360 photos | I suspect you will need to make them ... which might only mean ‘make from’ another item. Do you have the old/worn/bent ones as a pattern ? MichaelG.
Pete. | 07/05/2020 00:04:56 |
![]() 910 forum posts 303 photos | Sorry for hijacking your question, but it is on subject. I'm nearly finished restoring a mini 1940's milling machine, it doesn't have tapered gibs, I need to make a small gib strip, would a strip of en1a be suitable to make a gib strip from? I thought the lead in it might give it some lubricity? |
Michael Gilligan | 07/05/2020 00:33:52 |
![]() 23121 forum posts 1360 photos | Pete Personally ... I would use gauge plate, for its flatness, smoothness, etc. Lubricant can be applied . I’m sure there will be other opinions forthcoming. MichaelG. |
Steviegtr | 07/05/2020 00:44:00 |
![]() 2668 forum posts 352 photos | Interesting. No idea though. Why were they not originally made from phosphor bronze. Steve. Edited By Steviegtr on 07/05/2020 00:45:03 |
Pete. | 07/05/2020 00:46:05 |
![]() 910 forum posts 303 photos | I suppose gauge plate is harder so it might be better for vibration (not absorbing it and effecting surface finish?). I did measure some bright en1a flat bar with a mic, and it was surprisingly consistent along the length and close to spec, which made me wonder if it could be used as gib strip. It would be interesting to hear others opinions on it though. |
Steviegtr | 07/05/2020 01:12:39 |
![]() 2668 forum posts 352 photos | My take on this, is that a gib strip runs on usually cast iron. we all know from metallurgy that for 2 metal rubbing together that one would be made from a hard metal substance & one from a soft substance. Hence my reasoning of cast iron to Phosphor bronze. Especially as the bronze can be oilite. It will stay lubricated for longer than any other metal. Or is it too soft & would not pack correctly. Silly old duffer will have an answer in the morning I am sure that will blow my theory away. Steve. |
Michael Gilligan | 07/05/2020 08:02:38 |
![]() 23121 forum posts 1360 photos | Posted by Steviegtr on 07/05/2020 00:44:00:
Interesting. No idea though. Why were they not originally made from phosphor bronze. Steve. . Good morning, Steve Just wondering ... have you looked at the strips on your Myford ? MichaelG. |
Steven Kane | 07/05/2020 08:42:23 |
4 forum posts | High Michael, I do have the original gib strips in the lathe and would like to replace them with new items as I have a problem with inconsistent fit, resulting in tight spots. I was hoping that the sizes could be the same as say a ML 7? Myford quote online 8 1/2 inches long for the cross slide, but of course it doesn't say what the other dimensions are. Steven |
Michael Gilligan | 07/05/2020 09:06:48 |
![]() 23121 forum posts 1360 photos | Posted by Steven Kane on 07/05/2020 08:42:23:
High Michael, I do have the original gib strips in the lathe and would like to replace them with new items as I have a problem with inconsistent fit, resulting in tight spots. I was hoping that the sizes could be the same as say a ML 7? Myford quote online 8 1/2 inches long for the cross slide, but of course it doesn't say what the other dimensions are. Steven . I’m sure that collectively, the forum can compare the dimensions of various strips with what you have ... but that would be easier if we know what you need. If it’s any help: Here’s a couple of photos of my ML7R strip, in the condition I bought the lathe . . I think you will find it differs significantly from the ML4 version. Incidentally: I managed to straighten that and polish it back to useable condition MichaelG. Edited By Michael Gilligan on 07/05/2020 09:11:38 |
Jon Cameron | 07/05/2020 09:25:08 |
368 forum posts 122 photos | I think Michaels suggestion of gauge plate is a sound one. the strips are hard ground metal surface and gauge plate would fit the bill nicely. There will also be longer lasting than bronze ones which may flex with the limited adjusting screws on the ML4. Alternatively you could rub the original on some increasingly fine wet and dry with oil, on some plate glass or a granite chopping board. then once done check for flatness using a verdict DTI on the surface plate (granite chopping board). If you want to completely replace it then I think that gauge plate is your first option, not sure of the dimensions on the ML7 and how they compare to the ML4. but if they are the same, a new ML7 one cut down to size would be a more expensive option. |
Douglas Johnston | 07/05/2020 09:47:24 |
![]() 814 forum posts 36 photos | When I made some gib strips a few years ago I used gauge plate and did as Jon suggested to flatten one surface. Incidentally the thickness of the strip does not need to be perfect since the back face is only in contact with the gib screws. One other thing I did was to cut the ends with a sharp endmill (a new carbide one in my case ) so that the end edges in contact with the slide had no discernible rounding. This helps to prevent any fine chips getting trapped between the gib and the slide. Doug |
Hopper | 07/05/2020 10:17:42 |
![]() 7881 forum posts 397 photos | Posted by Steven Kane on 07/05/2020 08:42:23:
High Michael, I do have the original gib strips in the lathe and would like to replace them with new items as I have a problem with inconsistent fit, resulting in tight spots. Tight spots is usually down to wear on the cast iron ways on the cross slide or carriage. The more used area gets worn away over the years. Are you sure your problem is the gib strip? You should be able to rub your gib strips on emery paper on a slab of glass of granite etc to flatten them out as already suggested. They they are adjustable via the screws so flatness is not ultracriticical as they will conform to the pressure of the screws etc. To make new gibs you will need to machine the angles on the edges etc. Mild steel or gauge plate will work. It is rubbing against cast iron, so a good bearing combination. No need for bronze etc. |
SillyOldDuffer | 07/05/2020 12:59:20 |
10668 forum posts 2415 photos | Posted by Steviegtr on 07/05/2020 01:12:39:
My take on this, is that a gib strip runs on usually cast iron. we all know from metallurgy that for 2 metal rubbing together that one would be made from a hard metal substance & one from a soft substance. Hence my reasoning of cast iron to Phosphor bronze. Especially as the bronze can be oilite. It will stay lubricated for longer than any other metal. Or is it too soft & would not pack correctly. Silly old duffer will have an answer in the morning I am sure that will blow my theory away. Steve. Theory safe, but I can fill in some of the whys and wherefores! Not due to my natural genius, but I do have a collection of books!
Of these, not galling, generally means a bearing must be made of two different metals. The book says the main exceptions are: cast-iron may be run against cast-iron, and mild-steel may be run against hardened steel. Not any pair of different metals work without galling, examples of OK pairs given are:
So Phosphor Bronze is OTT for lathe gibs, cast-iron more likely, maybe mild-steel for cheapness, or brass because it can be polished. Big machine slides might be different, but gibs don't generally have to cope with high-pressure, high-loads, or high-speed. Be fun to fit silver gibs, massive boasting rights, and it would deter vampires! Dave Dave |
Steviegtr | 07/05/2020 13:33:54 |
![]() 2668 forum posts 352 photos | Posted by Michael Gilligan on 07/05/2020 08:02:38:
Interesting. No idea though. Why were they not originally made from phosphor bronze. Steve. . Good morning, Steve Just wondering ... have you looked at the strips on your Myford ? MichaelG. Yes Michael, they look like mild steel. Steve. |
Steviegtr | 07/05/2020 13:36:57 |
![]() 2668 forum posts 352 photos | Posted by SillyOldDuffer on 07/05/2020 12:59:20:
Dave Great write up you did there. Steve. |
Michael Gilligan | 07/05/2020 13:46:10 |
![]() 23121 forum posts 1360 photos | Posted by Steviegtr on 07/05/2020 13:33:54:
Interesting. No idea though. Why were they not originally made from phosphor bronze. Steve. . Good morning, Steve Just wondering ... have you looked at the strips on your Myford ? MichaelG. Yes Michael, they look like mild steel. Steve. . Dave has already done his duty well ... but I will just add that [suitable grade] cast iron is sufficiently ‘self lubricating’ to run well; either cast on cast, or steel on cast. Machine tool makers have been doing it for many decades. MichaelG. |
Steviegtr | 07/05/2020 13:47:54 |
![]() 2668 forum posts 352 photos | Posted by Michael Gilligan on 07/05/2020 13:46:10:
Interesting. No idea though. Why were they not originally made from phosphor bronze. Steve. . Good morning, Steve Just wondering ... have you looked at the strips on your Myford ? MichaelG. Yes Michael, they look like mild steel. Steve. . Dave has already done his duty well ... but I will just add that [suitable grade] cast iron is sufficiently ‘self lubricating’ to run well; either cast on cast, or steel on cast. Machine tool makers have been doing it for many decades. MichaelG. Ok keep your hair on. Too early to argue. Was only a thought. Steve. |
Michael Gilligan | 07/05/2020 13:53:06 |
![]() 23121 forum posts 1360 photos | Posted by Steviegtr on 07/05/2020 13:47:54:
Dave has already done his duty well ... but I will just add that [suitable grade] cast iron is sufficiently ‘self lubricating’ to run well; either cast on cast, or steel on cast. Machine tool makers have been doing it for many decades. MichaelG. Ok keep your hair on. Too early to argue. Was only a thought. Steve. .
No hair or argument involved. MichaelG. |
Steviegtr | 07/05/2020 13:56:42 |
![]() 2668 forum posts 352 photos | Posted by Michael Gilligan on 07/05/2020 13:53:06:
No hair or argument involved. MichaelG. Steve. |
