Stephen Follows | 18/04/2020 14:47:04 |
![]() 119 forum posts 3 photos | Does anyone have experience of using revel enamels with an airbrush? I thin my paint 50/50 but have trouble with second coats dissolving the first. Should I thin less? I leave twenty four hours between coats. |
Bob Stevenson | 18/04/2020 15:23:43 |
579 forum posts 7 photos | It's many years since my airbrush experiences but I think you are using too much solvent and not enough pressure...try experimenting by spraying into a plastic cup... I saw your other post re air reservoir. If your comp does not have one you can experiment by inflating a car spare tyre and tehn connecting the air brush....inflate to 40psi. As ever, a regulator with a conbined moisture trap is more or less essential for any serious airbrush use. All good comps such as the 'Bambi' units come with reservoirs and reg/trap......these units have been, and still are, quite pricey albeit UK made items, however, bambi no do a nice amateur model which is small and silent with decent sized reservoir and comes in at about £100 or less according to supplier/online etc.
If you look online/youtube there are people putting together their own comps.....Teh Steve Jordan video is probably the best one as he makes wha tis virtually a pro tool using a fridge unit. |
JasonB | 18/04/2020 16:16:24 |
![]() 25215 forum posts 3105 photos 1 articles | What are you thinning it with? 24hrs can be a bit too long, i've used a couple of paints that state recoat within a few hours but once past 24 you need to leave it several weeks before recoating. Edited By JasonB on 18/04/2020 17:41:25 |
HOWARDT | 18/04/2020 16:58:05 |
1081 forum posts 39 photos | Always used to use Humbrol in air brush, thinned down and used multiple coats, allowing to dry sufficiently between coats. Never had any trouble with getting good finish. I can’t remember what I used for thinner, may we’ll have been turps, as I don’t recall buying anything special. |
Dave Halford | 18/04/2020 17:53:57 |
2536 forum posts 24 photos | White sprit will thin enamel, use as little as you can to get the effect that you want. |
Dalboy | 18/04/2020 22:58:08 |
![]() 1009 forum posts 305 photos | Something else to take into consideration that thinning too much will affect the paint so thin less and if possible change the nozzle size on the airbrush. Some of the cheaper airbrushes don't have this facility |
Pete Rimmer | 18/04/2020 23:31:52 |
1486 forum posts 105 photos | Posted by JasonB on 18/04/2020 16:16:24:
What are you thinning it with? 24hrs can be a bit too long, i've used a couple of paints that state recoat within a few hours but once past 24 you need to leave it several weeks before recoating. Edited By JasonB on 18/04/2020 17:41:25 The enamel paint I use on my machines is like that. Second coat within 2 hours or leave 6 days otherwise it will trap the solvent in the first coat and could blister. |
