non-circular boring.. Literally - it is boring!
sam sokolik31/03/2020 04:10:11
126 forum posts
I decided to see if I could create a polygon shaped hole with a little math and a cnc..
And now in aluminum!
Edited By sam sokolik on 31/03/2020 04:16:05
Thor 🇳🇴31/03/2020 06:09:27
1766 forum posts
46 photos
Impressive Sam, now you should be able to make your own socket head cap screws.
Thor
Martin Connelly31/03/2020 09:41:57
2549 forum posts
235 photos
Looks useful. I expect the maths is similar to what is used for single point turning of polygons on CNC lathes with the added complication of a rotating tool.
Martin C
Brian H31/03/2020 12:43:13
2312 forum posts
112 photos
That's excellent Sam, thanks for sharing. I'm just beginning to find out about CNC and it's fascinating what can be achieved.
sam sokolik31/03/2020 14:01:20
126 forum posts
I expanded on the work Andy did...
He also did some grinding mock ups..
sam sokolik31/03/2020 14:18:49
126 forum posts
I also am working on the functionality of slaving the x axis to the radius of the polygon... SO you can do things like create a profile for the polygon to follow. So this is a radius into a taper..
blowlamp31/03/2020 15:54:31
1885 forum posts
111 photos
That's interesting stuff you're doing, Sam. yes
Could you post some gcode here please, so I can try it with my PlanetCNC control, which is designed to be LinuxCNC compatible?
I'll get Alan at cncyourmyford to have a look too as I'm sure he'll be interested.
Martin.
sam sokolik31/03/2020 17:12:10
126 forum posts
This is a simple hal component that takes the spindle posltion from the encoder and calculates where the x/y axis need to be to keep the tool tip perpendicular to the polygon. (well - to the inscribed circle.) This is done in the real-time layer of linuxcnc. So 1000 times a second it reads the spindle postion and calculates the polygon shape. I use currently the digital/analog i/o functionality in gcode to communicate with the component. I think it could be converted to remap to make it more user friendly. I don't have the gcode here at the moment but I think this is the latest hal component.
sam sokolik01/04/2020 05:14:09
126 forum posts
A hex bolt head isn't exactly a standard.. but..
Michael Gilligan01/04/2020 07:53:19
23121 forum posts
1360 photos
Nice !!
sam sokolik02/04/2020 01:11:05
126 forum posts
Hmm...
sam sokolik04/04/2020 01:18:53
126 forum posts
Broach this! (the vertical lines are the encoder resolution...)
Michael Gilligan04/04/2020 07:22:01
23121 forum posts
1360 photos
Comment rev.1
Very Very Nice !!
sam sokolik10/04/2020 16:55:17
126 forum posts
Ok - I need to get a higher resolution encoder.. Then The surface finish will be better and I will be able to go slightly faster.... (I might have to bake in backlash comp too.... (x axis has a bit of backlash))
sam sokolik13/04/2020 15:07:58
126 forum posts
Phase 2 - Better spindle encoder..
sam sokolik22/04/2020 05:08:13
126 forum posts
Almost done!
sam sokolik24/04/2020 05:19:44
126 forum posts
sam sokolik26/04/2020 22:10:53
126 forum posts
Encoder seems to work better...
Michael Gilligan26/04/2020 23:08:42
23121 forum posts
1360 photos
Comment rev.2
Even nicerer still
... I’m clean out of superlatives now angel
sam sokolik29/04/2020 15:43:20
126 forum posts
I think I get a D for effort...
