Here is a list of all the postings sam sokolik has made in our forums. Click on a thread name to jump to the thread.
Thread: Raspberry Pi 5 |
30/09/2023 16:10:51 |
well - for linuxcnc it depends on the realtime latency of the system. I have been running the PI4 with linuxcnc for a long time - but using a mesa ethernet card to do the heavy lifting. (step generation and such) The maximum jitter I get is around 50us or so. This is perfectly fine for external interfaces like mesa. Linuxcnc does have a gpio driver for the pi - but again you are limited to how fast the realtime kernel can twittle bits. I I goofed around with it a while back - and was getting about 10khz step rates. Not stellar... |
Thread: Emco Compact 5 cnc |
26/09/2023 01:41:16 |
I would just use the motor that is on it... I have.. With a decent drive - they work great..
Thread: Opinions of Mach3 Turn |
25/09/2023 16:00:10 |
The masso controller seems to have css and fpr but you cannot run them at the same time.. |
21/09/2023 23:26:22 |
Posted by Nealeb on 21/09/2023 20:44:14:
In my research I came across Eding CNC, which I found mentioned by someone who had set it up for a lathe. However, their website does not specifically mention lathe use; the nearest is something on the lines of, "...and through the use of specially-written macros, other machine types can be supported." In other words - you are on your own with this one! CSLabs CSMIO motion controllers do support threading. That means one of their more expensive 6-axis controllers, plus the encoder extension module, plus their own "Pro" software, not the basic free version, to make it all work. Definitely not cheap, although I have used one of their controllers in the past and they are nicely put-together bits of kit. After that, I reckon you are probably into the realms of much more expensive solutions aimed at commercial use. CSS and feed per rev - as far as I can see, G96 CSS is not supported (based on a comment from PlanetCNC in a support forum post). I know it is listed in the PlanetCNC manual, but I don't think that it is implemented. All the same, I have just tried entering it as a command in my PlanetCNC software (in simulation mode - no machine connected) and it is accepted - so who knows? However, I think G95 feed per rev is there, together with spindle speed feedback via an encoder for accurate threading. Apart from something like facing a faceplate, I'm not sure how significant lack of CSS is - even with my variable-speed manual lathe, I haven't found much need for it in practice. But I'm sure to be proved wrong some time! Edited By Nealeb on 21/09/2023 20:45:26 Edited By Nealeb on 21/09/2023 20:48:03 Css is awesome - surface finish and tool longevity... Linuxcnc (is free) does threading - css and fpr.. (and to start - you could use the printer port...) In the dev version of linuxcnc (well - the pre-release version) there is also roughing/finishing cycles.. (G70,71 and 72) sam |
21/09/2023 19:20:39 |
also - things like constant surface speed and feed per rev are really nice things to have.. I Know linuxcnc has it - I assume Acorn does.. Don't know about planetcnc.. sam |
Thread: The printer port isn't dead! (linuxcnc is cool and powerful) |
14/09/2023 15:20:59 |
Getting closer..... |
Thread: The beginning of the end for Copper telecomms |
31/08/2023 17:20:41 |
Posted by pgk pgk on 31/08/2023 15:34:01:
Posted by sam sokolik on 31/08/2023 12:56:09:
Posted by pgk pgk on 31/08/2023 08:15:16:
Superficially, Starlink looks like a good solution for rural areas. The reality for many of us is hills and trees. I don't think there's any way I could get a reliable Starlink connection here. Equally, the location of cell towers rarely gives more than 1 bar outdoors unless I walk across 2 fields and climb the hill to the south. The nearest fibre cabinet is some 3 miles away, and it'll be a while (if ever) before any company justifies running fibre to the scattered few dwellings here. If the copper goes down and one is too ill or injured to drive to an area with a cell signal it'll simply be game over. pgk If you want to check it out - Starlink has an app that uses your cell camera and location to see if there are obstructions... I spotted that today when looking at their site. At ground level by the house there's no chance and I can't see me climbing on top of the chimney to use my cell phone 😔 The only ground level test would be 150 yds from house for a sporting chance..a long way to post and cable.. Where is your sense of adventure? I think it only comes with a 50ft cable and you can get a 150ft cable.. |
31/08/2023 12:56:09 |
Superficially, Starlink looks like a good solution for rural areas. The reality for many of us is hills and trees. I don't think there's any way I could get a reliable Starlink connection here. Equally, the location of cell towers rarely gives more than 1 bar outdoors unless I walk across 2 fields and climb the hill to the south. The nearest fibre cabinet is some 3 miles away, and it'll be a while (if ever) before any company justifies running fibre to the scattered few dwellings here. If the copper goes down and one is too ill or injured to drive to an area with a cell signal it'll simply be game over. pgk If you want to check it out - Starlink has an app that uses your cell camera and location to see if there are obstructions... |
31/08/2023 02:27:08 |
good riddance. My parents only decent internet was dsl (copper phone lines) (here in the US) and it sucked. They were lucky to get 1mbsX128kbs. (and it was down all the time) The second starlink came available - I told them to sign up for the beta.. They got in and have been using it for the last few years. I can count on 1 hand how many times it was down (that we noticed) Speeds are variable but are around 100mbsX10mbs (at least) They now don't worry about the internet. It just works. Do you guys have cell service that allows calling over the internet? That is what I use. I can make cell phone calls from within the machine shop at my parents - 0 cell signal - all through the internet. (starlink) works great also.. (so my parents cut the cord) sam |
Thread: Improving hobby-grade Servos |
27/08/2023 22:36:45 |
Why not use something that has been improved on for years and being used daily for real machines? Linuxcnc will allow you to do true closed loop control. I am even doing it through the the printer port (obviously speed limited) but very accurate using PID. Using basic pwm amplifiers - My lathe currently uses $5us drives from amazon. It has 9 axis of coordinated motion.. You can start as simple as this for closed loop... (replace the amc drive with the $5us drives from amazon.) Plus you can buy inexpensive external interfaces that do hardware encoder counting, high speed step/dir and high speed pwm (among other things)
12/08/2023 16:18:35 |
+/- 10 volts out of the printer port.. |
Thread: Myford CNC Conversion Kit - Tony Jeffree |
08/08/2023 18:12:12 |
Posted by Ady1 on 08/08/2023 18:00:18:
I think there are parallel port adapters about ported onto a usb connection No guarantee that it will communicate 100% though, you have to buy and try Edited By Ady1 on 08/08/2023 18:01:42 usb to parallel port adaptors will not work in this situation...
sam |
07/08/2023 16:38:39 |
Finally had a little time to work on this project. I got the X ball nut assembly done - it took some creative machining... |
04/12/2022 18:11:11 |
an hour you won't get back...
29/11/2022 18:13:33 |
A bit of ladder for testing... |
29/11/2022 18:11:13 |
Finally scored a compact 5 turret!
Edited By sam sokolik on 29/11/2022 18:11:46 |
Thread: Macro-photography |
06/10/2022 20:19:50 |
been really impressed with my pixel phone... (4a 5g) |
20/09/2022 05:01:28 |
Saving a pin on the printer port using missing tooth functionality.. (to create an index pulse)
10/09/2022 23:43:26 |
Very cool! Yes - the hard part is making it deterministic... I can't say I fully understand how linuxcnc does it. It uses the rt_preempt kernel (which is now part of the Debian repository) They use the real time api to create the threads. You can isolate cores for real time - it helps but you won't get mhz thread. (at least in my experience) For machine control - most of the 'control' can be done in a relatively slow thread. (1 - 10khz) calculating the PID, Trajectory and stuff.. The faster stuff can be moved to hardware. (but again - still doable in the computer as long as 50khz works..) sam There is also an RTAI patched kernel which is still available - but requires a bit more work. It used to be that it performed better than the rt_preempt kernel but in my experience they usually have similar latency now. sam |
09/09/2022 15:17:07 |
Little update.. Made some 3d printed parts to mock up the new ball screw.. Looks good. I think all I have to do is move the ball screw out about .050" or so. Edited By sam sokolik on 09/09/2022 15:42:33 |
