Norman Frodsham | 09/03/2020 13:38:48 |
1 forum posts | I have an old Kitty P/T 636, the machine works well apart from the starter switch which has just packed in. I live in New Zealand so the chance of finding the same switch is remote. It appears to be a no volt release, capacitor start 240 V single phase. any ideas how I might get round this as the machine is to good to scrap. Norm |
Brian Morehen | 09/03/2020 17:44:54 |
![]() 191 forum posts 11 photos | Any Electrcal store will be able to advise you on a suitable replacement , If in the UK no problem New Zealand I dont now what is available? Good Luck Brian M |
Bazyle | 09/03/2020 22:39:14 |
![]() 6956 forum posts 229 photos | If the switch is neatly fitted into the body casting you probably won't find a like for like replacement. However you can just get a NVR switch for the same size motor HP or current consumption and put it in a box. As a TP doesn't run in reverse it makes the wiring easier but if you don't understand electrical things you will have to find a professional. |
Emgee | 09/03/2020 22:58:32 |
2610 forum posts 312 photos | Check this previous post, plenty of info there. Kity W oodwork Machine Switch AgainEmgee
Bruce Edney | 10/03/2020 03:55:35 |
![]() 167 forum posts 53 photos | Hi Norm What does the switch look like? And where in NZ are you located? Cheers Bruce |
larry phelan 1 | 11/03/2020 08:37:45 |
1346 forum posts 15 photos | Don't think it needs to be fitted into the machine, any standard NVR switch to suit the HP should be OK.. I had a similar problem with a garden shredder last year, switch was built in, so I just by-passed it and fitted a new switch with its own mounting box. Problem solved ! |
Russell Eberhardt | 11/03/2020 10:11:33 |
![]() 2785 forum posts 87 photos | Would something like this be what you're looking for. What is the power rating of the motor? https://www.ebay.com.au/itm/250V-Universal-KJD20-2-NVR-Safety-Switch-Emergency-Stop-Saftey-Cut-Off-Killer-To/232472053773?epid=2217195796&hash=item36206a080d:g:AvEAAOSwqAldZQWQ Russell |
