Russ B | 20/02/2020 10:17:07 |
635 forum posts 34 photos | I picked up a £29.99 cordless angle grinder (no battery, no charger) as I already had a 4Ah battery and charger that came with the £59.99 400nm impact gun (which is a superb quality piece of kit, and its got some serious oomph, way more than any pneumatic hand held gun ive used!) Back to the grinder.... 2 issues, the no load speed is only about 7500rpm, not the 10,000 advertised, I didn't charge my battery (as I dont intend on using it and long term storage outside of 30-60% charge is very damaging for a lithium pack). My 3 bar battery indicator shows full, however these show full at anything over about 30% from what I've read online, so not to be trusted. I'll charge it up tonight and see how it goes. Issue 2... Overall, looks nice, but the quality is absolutely no where near that of the big 400nm impact driver I bought. Bit of a let down to say the least. Although it was only £29.99 and I've got the battery and charger and I'm sure it'll do exactly the job its supposed to - I'm still tempted to take it back.
Ady1 | 20/02/2020 11:06:20 |
![]() 6137 forum posts 893 photos | I would take it back and wait for the corded 240v angle grinder if I were you The corded one is fabby, like the impact gun, a pure pleasure to use I use a battery drill driver, they have incredible low speed torque, that battery compressor is great, the battery impact guns are weak but great for general nut and bolt work Of course this may be the one tool that saves your a** one day because it is so portable... My main worry would be whether it has enough high speed grunt to cut properly, which is harder to achieve for a battery than low speed grunt A small grinder disc cuts up to 3 inches away from the power delivery centreline which is very different from drilling holes and screwing screws GL |
larry phelan 1 | 20/02/2020 12:23:35 |
1346 forum posts 15 photos | Those grinders are a heap of crap. My friend bought one [ignoring my advice ] and found that it would not accept a grinding disc, only the cutting disc which came with it and lost power after a very short time. Best left alone. |
Robert Atkinson 2 | 20/02/2020 12:43:39 |
![]() 1891 forum posts 37 photos | Don't keep one in your car or carry it around. You are committing the crime of "going equipped" or to be exact "A person shall be guilty of an offence if, when not at his place of abode, he has with him any article for use in the course of or in connection with any burglary or theft." Applies to a lot of tools of course but battery grinders are used a lot for theft including bikes and catalytic converters. |
Bezzer | 20/02/2020 14:46:15 |
203 forum posts 16 photos | Posted by Robert Atkinson 2 on 20/02/2020 12:43:39:
Don't keep one in your car or carry it around. You are committing the crime of "going equipped" or to be exact "A person shall be guilty of an offence if, when not at his place of abode, he has with him any article for use in the course of or in connection with any burglary or theft." Applies to a lot of tools of course but battery grinders are used a lot for theft including bikes and catalytic converters. Rubbish, offence is only committed if it can be proved it's intended for something illegal- burglary or theft. Just having a battery angle grinder is not any kind of offence. |
old mart | 20/02/2020 16:08:45 |
4655 forum posts 304 photos | I'm a bit out of touch with recent Lidl diy stuff, is the grinder 12 or 20V? |
Ady1 | 20/02/2020 16:42:56 |
![]() 6137 forum posts 893 photos | They are congregating most of their kit around a generic 20v system at the minit so some stuff can be sold without a battery+charger most of my stuff is the old 12v system but I need lighter kit because of thumb and wrist trubbles The 20v system will be more powerful but there's a weight penalty to deal with Edited By Ady1 on 20/02/2020 16:47:14 |
Russ B | 20/02/2020 16:48:31 |
635 forum posts 34 photos | Ady, I'm cuffed to bits with my 20v impact gun (the biggest of 3 or 4 models they did) it's extremely powerful and top quality, mag alloy casing etc. I've got a 240v grinder I already (B&Q pro, done a hell of a lot of mileage over the last 10 years, getting noisy now, never serviced it....) I was buying this cordless grinder based on the quality of the impact gun. Larry...... Yeah, you've hit the nail on the head I think. I'll check this will take a grinding disk but I don't think it matters, it's going back, the poor quality of the plastic switch alone is an indication of everything else, CLEARLY not cut from the same cloth as the 400nm 20v impact gun. Old Mart the 12v stuff I've seen just doesn't have the guts, but some of it is extremely portable, perfect for light tasks, general screwing drill driving die grinding etc.
Lesson learnt, even though the range of 20v powertools from Lidl use the same battery charger, they are clearly not all made to the same standard, take each one in your hand and judge quality! (Wasn't possible in this case, they were all cable tied shut)
Ahhh well... |
Ady1 | 20/02/2020 16:53:34 |
![]() 6137 forum posts 893 photos | I missed that impact gun Russ, lucky you, I will look out for it Got the corded gun which has yet to be defeated by a wheelnut or anything else |
Russ B | 20/02/2020 17:13:40 |
635 forum posts 34 photos | Posted by Ady1 on 20/02/2020 16:53:34:
I missed that impact gun Russ, lucky you, I will look out for it Got the corded gun which has yet to be defeated by a wheelnut or anything else Well worth keeping an eye out for it just make sures it's 400nm and not the 300 or less, it's motor is 4x the size!! I had to take a big 32mm nut off my dad's van that hasn't moved since 98' and has andbeen well soaked in road salt, it blitzed it straight off, me and him were getting ready for a fight. It hit it so hard it damaged the flanks of the nut even with a good 6 sided impact socket (which wasn't welcome but we know to dial it down a bit next time, it has a digital torque selector on the grip, a button cycles through them) |
SillyOldDuffer | 20/02/2020 17:26:53 |
10668 forum posts 2415 photos | Posted by Mick Berrisford on 20/02/2020 14:46:15:
Don't keep one in your car or carry it around. You are committing the crime of "going equipped" or to be exact "A person shall be guilty of an offence if, when not at his place of abode, he has with him any article for use in the course of or in connection with any burglary or theft." Applies to a lot of tools of course but battery grinders are used a lot for theft including bikes and catalytic converters. Rubbish, offence is only committed if it can be proved it's intended for something illegal- burglary or theft. Just having a battery angle grinder is not any kind of offence. Not rubbish at all. To get a conviction, the prosecution only has to show you're away from home, have the tool, and have an intent to use it. In practice showing 'intent' is woolly, down to a court to decide. A tradesman with a legitimate reason for having tools in his van is much safer than a youth caught going into a bike shed with an angle grinder up his jumper. Better to have a solid reason for having the thing than to claim it's not a crime until they've proved intent. Won't be a problem if the officer is persuaded, otherwise he'll have you down the station, an unpleasant time-waster even if they subsequently decide not to proceed. Best advice about the law is to steer clear. Although it's amazing what ne'er do wells get away with, the full weight of the law tends to fall on anyone rich enough to pay fines whilst being too poor to pay a QC. My local paper often reports yobbos going equipped getting Community Orders, whilst a middle-class gent is fined £500 for letting his dog foul the footpath. Dave |
Bezzer | 20/02/2020 17:52:05 |
203 forum posts 16 photos | Posted by SillyOldDuffer on 20/02/2020 17:26:53:
Don't keep one in your car or carry it around. You are committing the crime of "going equipped" or to be exact "A person shall be guilty of an offence if, when not at his place of abode, he has with him any article for use in the course of or in connection with any burglary or theft." Applies to a lot of tools of course but battery grinders are used a lot for theft including bikes and catalytic converters. Rubbish, offence is only committed if it can be proved it's intended for something illegal- burglary or theft. Just having a battery angle grinder is not any kind of offence. Not rubbish at all. To get a conviction, the prosecution only has to show you're away from home, have the tool, and have an intent to use it. In practice showing 'intent' is woolly, down to a court to decide. A tradesman with a legitimate reason for having tools in his van is much safer than a youth caught going into a bike shed with an angle grinder up his jumper. Better to have a solid reason for having the thing than to claim it's not a crime until they've proved intent. Won't be a problem if the officer is persuaded, otherwise he'll have you down the station, an unpleasant time-waster even if they subsequently decide not to proceed. Best advice about the law is to steer clear. Although it's amazing what ne'er do wells get away with, the full weight of the law tends to fall on anyone rich enough to pay fines whilst being too poor to pay a QC. My local paper often reports yobbos going equipped getting Community Orders, whilst a middle-class gent is fined £500 for letting his dog foul the footpath. Dave You are obviously ignoring the first line of what I called rubbish " Don't keep one in your car...You are committing an offence" which is total rubbish. Your interpretation/opinion has nothing at all to do with my reply which was just to the point that it's wrong. I don't need your barrack room lawyer spouting off with a lecturing "what's what", I know what I'm on about and I was right in what I said, actually dealing with the offence many times over 30years in the police helps a lot. |
Mike Poole | 20/02/2020 18:01:18 |
![]() 3676 forum posts 82 photos | Ideal to have in the car if you get clamped Mike |
Robert Atkinson 2 | 20/02/2020 18:16:33 |
![]() 1891 forum posts 37 photos | I stand by what I said, please don't edit what I said to suit your case. Robert G8RPI. |
Bezzer | 20/02/2020 19:42:07 |
203 forum posts 16 photos | What have I editted that makes any difference to your misleading post? Since when has having angle grinder in your car makes it made or adapted to commit theft/burglary.?
Robert Atkinson 2 | 20/02/2020 20:03:09 |
![]() 1891 forum posts 37 photos | Posted by Mick Berrisford on 20/02/2020 19:42:07:
You removed "or carry it around" leaving just the car part. I just quoted the law on made for or adapted items, I did not say that a grinder met that test. Edited By Robert Atkinson 2 on 20/02/2020 20:03:51 |
SillyOldDuffer | 20/02/2020 20:45:16 |
10668 forum posts 2415 photos | Mike, Your choice of words is unnecessarily aggressive. Using the word 'Rubbish' on Robert and accusing me of being a 'Barrack Room Lawyer spouting off' is surely excessive. Try to keep it polite please. Dave |
Nick Hulme | 21/02/2020 10:30:17 |
750 forum posts 37 photos | Posted by Robert Atkinson 2 on 20/02/2020 18:16:33:
I stand by what I said, please don't edit what I said to suit your case. Robert G8RPI. Complete and utter bunk, if you have no previous and are of good character you need have no fear in carrying anything which isn't illegal in itself, no one will be interested. |
martin perman | 21/02/2020 10:51:45 |
![]() 2095 forum posts 75 photos | Gentlemen, Once again a resonably interesting post has turned into a barrack room brawl, does it always have to end this way and spoil everything. We all have our opinions whether right or wrong but dont spoil the post, do it somewhere else. Martin P |
larry phelan 1 | 21/02/2020 13:05:18 |
1346 forum posts 15 photos | Don't think that "grinder" would get you into any trouble since I doubt if it would last long enough to cut anything ! Looks like junk Feels like junk Is junk. |
