Myford fit collets
paul humphries11/02/2020 18:36:17
16 forum posts
Hi,
I am thinking of a collet set up for a ML10 . I am mainly going to hold small gears etc for boring out rather than holding tools so I am leaning towards ER 25 on a backplate rather than using the MT. Is this the best way to go? I know i will have to machine the backplate but I must confess to being slightly confused as to which parts to machine.
Paul
David George 111/02/2020 19:02:58
2110 forum posts
565 photos
If you grip jobs in a ER collet it needs to be tightened very tight or it won't run true and very short jobs won't grip properly. What type of gears are you making diamiter and thickness.
David
paul humphries11/02/2020 20:04:27
16 forum posts
Hi David about 16 to 20mm worms and spur gears that need to be reamed.
Paul
JohnF11/02/2020 21:21:08
1243 forum posts
202 photos
Assuming the ML10 has an MT2 in the spindle then the ER collets are your only option, however I would consider ER32, that what I use on my Super 7. The ER25 will not hold your 20mm dia components.
John Haine11/02/2020 22:05:26
5563 forum posts
322 photos
I have an ER40 chuck on a bib-bore 7 but the principle is the same.
The backplate screws on the spindle nose just like a standard chuck backplate.
There is an oversize register on the backplate that you then machine concentric and a very good fit (slightly tight) into the recess on the collet holder part.
Then bolt the holder part in place and you're good to go.
Buy a ball bearing collet closer to make it easier to get good clamping force.
paul humphries11/02/2020 22:16:49
16 forum posts
Thanks John.
JasonB12/02/2020 06:56:16
Posted by JohnF on 11/02/2020 21:21:08:
Should not be a problem to fit a 5C chuck to the Myford, I have held spur gears in my 5C collets a number of times and they grip at the end.
Another alternative would be to get some soft jaws for your existing chuck that can be machined in-situe and give the best contricity of all the options, again that is how I hold larger spur gears. A slight step in the soft jaws make sit easy to eliminate any wobble that you can get when gripping by just the edge.
If you do go with ER then you will need to make a plug to go in teh back end so they close down parallel onto the spur gear
Edited By JasonB on 12/02/2020 07:30:20
