Wiring nvr switch query
Pete.28/01/2020 23:05:28
910 forum posts
303 photos
I've just removed this small motor from my lathe with the intention of using on something else, it has a 2 direction switch wired up, if I could have some input from you clever electrically minded folk, I want to wire it with a simple NVR switch, no reverse needed, the motor has 2 live and 2 neutral, how do you do this on this setup with 4 wires?
Please excuse my ignorance on electrical matters.
I'll upload a photo in a moment.
Edited By Peter F on 28/01/2020 23:10:02
Edited By Peter F on 28/01/2020 23:10:39
Pete.28/01/2020 23:08:38
910 forum posts
303 photos
Motor 1
Pete.28/01/2020 23:09:31
910 forum posts
303 photos
Motor 2
Steviegtr28/01/2020 23:14:31
2668 forum posts
352 photos
That looks like a start relay so the motor may have start & run windings. Some do. That could be connected to a timer or a centrifugal switch on the motor shaft.
Steve.
Pete.28/01/2020 23:24:17
910 forum posts
303 photos
Posted by Steviegtr on 28/01/2020 23:14:31:
Steve.
Thanks Steve, do you know how to wire up a simple 2 wire nvr switch rather than the 2 direction switch currently fitted?
Steviegtr28/01/2020 23:33:58
2668 forum posts
352 photos
From your picture I would not know. Without a wiring diagram I cannot help, sorry. Maybe someone will be along who can help.
David George 129/01/2020 08:31:57
2110 forum posts
565 photos
Sometimes there is a wiring diagram on the inside of the cover but failing that is there a plate on the motor. There seems to be markings on the cables that may give a bit of a clue, draw a sketch with cable markings and conections woukd help.
David
Brian Morehen29/01/2020 08:40:12
191 forum posts
11 photos
Any Control Fitted into the mains lead that is a D O L has NVR and Thermal overload wiil not affected any other motor controls that hve not been touched..
Steviegtr29/01/2020 14:34:01
2668 forum posts
352 photos
I am struggling as to what the NVR means. Is it a No volt relay. Like a lot of new pillar drills/ bandsaw & the like have fitted. Which are like a latching push start & combi stop button. Doing away for the need of a contactor.
Steve.
Ian Parkin29/01/2020 14:51:54
1174 forum posts
303 photos
Stevie
NVR is No Volt Release
so a contactor is nvr
the modern little green and red start stop modules have a latch which is magnetically held in so when power is interrupted the switch latches off so when power is resumed a machine won’t start up
