Vic | 22/01/2020 13:49:37 |
3453 forum posts 23 photos | I would like to use some Torx socket set (grub) screws for some projects but can’t seem to find a supplier. There is one hit that comes up in the UK but it’s for quoting so suspect they won’t be interested in supplying 10 off of a particular size! Not sure of sizes yet but metric from M3 to M6. |
HOWARDT | 22/01/2020 15:22:25 |
1081 forum posts 39 photos | As most are wondering but not asking, why Torx, what are you hoping to gain over straight Allen grub screws.
Vic | 22/01/2020 16:35:41 |
3453 forum posts 23 photos | Torx are much less likely to round off the socket, particularly in the smaller sizes. |
not done it yet | 22/01/2020 17:05:26 |
7517 forum posts 20 photos | Counterbore and use screws? There were two sources on the single ‘goggle’ page I searched on. |
Vic | 22/01/2020 17:15:20 |
3453 forum posts 23 photos | I found one size - M5x5 on eBay quite some time ago but they were in Germany and not cheap. Using Google.de I’ve found These - bottom of the page. |
John MC | 22/01/2020 17:26:10 |
![]() 464 forum posts 72 photos | The problem I have found with Torx is that the next size down (to the correct size) key almost fits, without care it can easily be mistaken for the correct size key. If the fastener isn't too tight it will undo. If its tight then rounds out the socket nicely. My local BMW motorcycle dealer hates them because of this, they are frequently asked to remove a damaged Torx fastener by owners who are unfamiliar with them. John |
Vic | 22/01/2020 17:44:23 |
3453 forum posts 23 photos | Posted by John MC on 22/01/2020 17:26:10:
The problem I have found with Torx is that the next size down (to the correct size) key almost fits, without care it can easily be mistaken for the correct size key. If the fastener isn't too tight it will undo. If its tight then rounds out the socket nicely. My local BMW motorcycle dealer hates them because of this, they are frequently asked to remove a damaged Torx fastener by owners who are unfamiliar with them. John I must admit I’ve never had that problem and the Torx carbide insert screws on some of my tooling go down to M2.5. |
Swarfy | 22/01/2020 17:54:46 |
25 forum posts | Posted by Vic on 22/01/2020 16:35:41:
Torx are much less likely to round off the socket, particularly in the smaller sizes. Have to agree there torx are far superior in small sizes ,that’s why toolholders have torx to hold the inserts in |
D.A.Godley | 22/01/2020 19:02:23 |
143 forum posts 41 photos | Posted by Vic on 22/01/2020 13:49:37:
Vic, At the recent London MX , I noticed that one trader had a range of Torx screws being sold individually , from what I recall , it would have been MA Tooling 07973843142 , or possibly Peak Tools , Of Hope Valley , Derbyshire . I am sorry I can’t be more definite as to which it was , but the image of the tray at the end of the stand is very clear in my recollection, and if it helps anyone else remember , the stands were close to the displays of boats . Hope it’s of some help
Ian P | 22/01/2020 19:25:30 |
![]() 2747 forum posts 123 photos | Posted by John MC on 22/01/2020 17:26:10:
The problem I have found with Torx is that the next size down (to the correct size) key almost fits, without care it can easily be mistaken for the correct size key. If the fastener isn't too tight it will undo. If its tight then rounds out the socket nicely. My local BMW motorcycle dealer hates them because of this, they are frequently asked to remove a damaged Torx fastener by owners who are unfamiliar with them. John Torx are not unique to being damaged by use of the wrong size size key or tool. I have even heard of hexagon nut getting rounded corners. I would have thought the BMW dealer would be happy to take on work caused by the customer damage, after all its business. Ian P |
Vic | 22/01/2020 20:50:44 |
3453 forum posts 23 photos | Posted by D.A.Godley on 22/01/2020 19:02:23:
Thanks for that. |
