Here is a list of all the postings Swarfy has made in our forums. Click on a thread name to jump to the thread.
Thread: Boxford aud |
18/07/2020 08:18:27 |
I managed to get on the bolt in the end and got about 3 turns on it so great I will also follow your advice with the meshing setting thanks again all
17/07/2020 08:47:15 |
Well thanks everyone for all the help and advice and thanks very much bazyle for the info on the hold down bolts both of which weren’t done up anywhere near tight the front one was actually floppy .i still have the increase in noise when feeding towards the chuck not as noisy feeding away and not a thing in neutral the tumble gears bazyle mentions if I’m looking at the right gears don’t seem to have bearings just fitted to an eccentric shaft ? Tia
16/07/2020 12:46:41 |
Managed to get the spindle out not sure how you tell if roller bearings are knackered but they both look very good I tried to get a spanner on the headstock hold down bolt but couldn't now the shaft is out I notice the plate is loose why it didn't show before is beyond me any idea of the size and how on earth did you make a spanner? Cheers for all the advice, where are the bearings in the tumbler gear as mentioned for checking
16/07/2020 11:11:52 |
Morning all Have stripped it down to just needing to remove the spindle I can feel slight Movement if I grab each end of the end of the spindle and there is slight side to side On the disc where the belt runs on the shaft, the whole thing moves probably 10though ish I took the two gears off the selector shaft (with the nuts behind) 9 on the eccentric pins both were loose is that correct sorry to seem dumb but I've never had a Boxford before! Give me a cnc sliding head anyday, sorry if I'm not explaining it very well Tia
15/07/2020 19:18:40 |
Hi haven’t logged on lately as I’ve been busy with woodworking projects .i bought my boxford aud a few months back but haven’t really used it much till lately now I’m using it a couple of things I think are needing attention the first one being noise ,when the lever that engages forward or reverse traverse is engaged it is very noisy when in neutral it’s fine but going towards the chuck the traverse is noisy even with no movement taking place ? The other thing that’s worrying me is when turning or drilling quite heavy it looks to me like the chuck or headstock is getting pushed back only very slightly but when you back of it seems to spring back only very slightly but definetley movement I tried a bar under the chuck and there doesn’t seem to be any play up or down am I being petty ? Tia |
Thread: Boxford Toolpost |
27/03/2020 17:50:34 |
Hi all I ordered two T51 toolholders from Amazon that finally arrived today the advert states for boxford 125mm to 150mm centre height which I thought was right .They are way too small have I ordered the wrong ones ? The ones I have are 73 mm long by 44mm high approx the ones they sent are about 20mm smaller they also stated will hold 16mm square but the gap is only 13mm ish . I’m sending them back but need to order a couple from somewhere else any help much appreciated |
Thread: New lathe |
14/03/2020 17:03:17 |
Well it’s in the workshop and have spent quite a few hours cleaning and levelling it ,I must say I’m pleased with it I checked the serial number and it seems to be a late model from rom1978/9 |
10/03/2020 18:29:25 |
Thank you all very much for your advice I’ve decided to go for the Boxford ,probably be asking dozens of questions but hey ho |
09/03/2020 17:29:39 |
I’m going to have another look tomorrow hopefully I’ve never run a Boxford only a Colchester and CNCs how do I check the gearbox ? Visually or by sound and he had a bit of a job changing the lever over on the traverse but I think that was mainly because I was standing there .thanks for all the comments so far |
09/03/2020 15:09:17 |
thanks that was quick and very decisive anything I need to be concerned about lads ? Tia |
09/03/2020 14:30:36 |
Well that’s put the cat among the pigeons ! Although I ordered the warco wm250v at just over 2k with stand a Boxford AUD mk3 has just come up for sale less than a mile from me been to look and seems good ex school machine so interlocks abound he is asking £1200 and for that all being well he will deliver and put it in my workshop which is no mean feat any advice ? Should I cancel the modern warco and get the Boxford ? Help |
Thread: Chronos multifix toolholder |
06/03/2020 20:33:02 |
Looking at getting one of these for my new WM 250v lathe ,I’m thinking at least it’s in the UK as any gear from China like create make might be a problem getting .anyone got anything to say about the chronos offering ? Good or bad tia mick |
Thread: New lathe |
06/03/2020 12:16:52 |
Well I finally ordered my lathe spent ages looking trying to decide but wanted a new lathe and a once only buy so decided I was going for the warco wm 250v with a stand but been out of stock for ages but they finally became available again yesterday I had decided to wait for there open day to have a look and hopefully get a deal but found out today it’s been cancelled due to corona virus worries but you could still get a show deal if you phoned up which I did .didnt get much off but saved myself a few quid now just have to wait .they said that you would they have another shipment of lathes on the way but after that who knows when the next lot will be available so if your thinking of buying it might be an idea to enquire sooner rather than later |
Thread: Help choosing my lathe |
27/01/2020 10:29:17 |
Well despite telling me i could order on line in turns out i cant so the 10% off code cannot be used .i must say I'm very unimpressed by there attitude to a potential new customer im beggining to think i might look elsewhere ? You would think that they would be pushing to sell a machine but obviously they dont need the sales ive never bought a new machine without some kind of discount or freebies seriously got to go away and think about this .very un impressed with warco customer service |
25/01/2020 20:54:30 |
Posted by jimmy b on 25/01/2020 08:59:17:
Funnily enough I have had a discount code from Warco this mornin,via email, its SAVEJAN
Good luck, I think it's this weekend only. I just went on the warco site and the code is on there but won’t let me order as its out of stock .i had an email from them last week and the Lady stated I could order by email or phone so I’ve contacted again asking for the 10% off ,thanks for that anyway will let you know mick Jim
24/01/2020 18:04:32 |
Thanks everybody all I need to do now is decide which (metric I’m sure )and order my 250V anyone got any discount codes for warco ? |
Thread: What a nightmare |
24/01/2020 17:46:46 |
That’s one reason you often see scrap cars on transporters going to a scrap yard have part of the number plate obscured do they can’t be cloned apparently |
Thread: Digital verniers |
24/01/2020 17:35:40 |
I would always recommend mitutoyo for callipers and mics but Tesa and Etalon make very good micrometers also in truth you only get what you pay for . |
24/01/2020 07:13:10 |
Is that lucas cav ? We manufactured parts for you where i used to work many years ago |
22/01/2020 19:26:15 |
Thanks for your replies im erring towards metric as the resale value on imperial might be affected dont get me wrong i had 5 cnc machines and all but one were programed by me in metric the hardinge lathe i kept imperial as that was my first machine and all my jobs at the start were imperial pipe fittings Mick |
