Cenetc 2A Horizontal Arbor Mill
martin cross 119/01/2020 16:52:28
43 forum posts
59 photos
Having recently bought and now checked over the 2A, I see that the arbor is completely plain; as in there is no milled slot to take any form of locking key to stop the cutters from turning on the arbor. Is the Centec unusual in this area or do I need to get a slot milled into it. The arbor looks original, left hand thread to undo, 2MT on the taper, just no slot in it?
I couldn't check before as the machine was set up and had a cutter in place which rotated etc, so I took it for granted that it was all there.
Thor 🇳🇴19/01/2020 17:07:24
1766 forum posts
46 photos
Hi Martin,
The lack of keyway in the arbor was discussed here.
Thor
Dave Halford19/01/2020 17:32:07
2536 forum posts
24 photos
As Thor link, there's nothing wrong with the arbour.
martin cross 119/01/2020 17:41:11
43 forum posts
59 photos
That's good news. Thanks for the help!
Dave Halford19/01/2020 21:02:43
2536 forum posts
24 photos
Have you changed the gearbox oil?
martin cross 119/01/2020 22:33:37
43 forum posts
59 photos
Not changed it yet, but not used it either. Just run it up to check switches and gears etc. It appears to have a soft start on hi speed gears taking several seconds to reach full speed.
not done it yet19/01/2020 22:57:18
7517 forum posts
20 photos
If it is a single phase motor, it is likely struggling to get to speed in top gear, particularly if the oil is thick and cold.
My 2B, with a one horse motor, would not start in high gear until warmed up. I changed it to a 3 phase motor and no problem since. The 2A may well have a 3/4 HP motor (particularly if it is original).
