David Canham | 04/01/2020 21:15:36 |
![]() 50 forum posts 15 photos |
I was sorting through some taper shank drills and sleeves in a workshop that i help to maintain. I found them in an old filling cabinet in the corner of the works. There were some good drills in the assortment, some up to 2" in diameter and either Dormer or Presto so worth a few quid. Then i came across the sleeve as pictured. At first i thought it was full of crud but it actually has a flat section inside the taper. I have never seen that before and so i thought i would share it with you clever people. So, is it a drill sleeve or something else. |
Alan Waddington 2 | 04/01/2020 21:20:11 |
537 forum posts 88 photos | Can’t provide an answer, but iv’e also got one floating about in my drill drawer. |
old mart | 04/01/2020 21:23:35 |
4655 forum posts 304 photos | Its made in Iowa, so it could be anything. I notice the name is "use em up", I wonder if it is designed to salvage scrap MT3 tapers by grinding a flat on them? It could be worth asking on The home shop machinist forum. Edited By old mart on 04/01/2020 21:25:16 |
Michael Gilligan | 04/01/2020 21:28:11 |
![]() 23121 forum posts 1360 photos | The clue’s in the name ... it allows obsolete Blacksmith’s Drills [‘Armstrong Taper’ I think] to be fitted in a Morse Tapered machine. MichaelG. |
David Canham | 04/01/2020 21:53:36 |
![]() 50 forum posts 15 photos | Thanks Michael, I think i'll keep this a paper weight if as you say it has an Armstrong taper. David |
ega | 04/01/2020 23:37:24 |
2805 forum posts 219 photos | Posted by old mart on 04/01/2020 21:23:35:
Its made in Iowa, so it could be anything. I notice the name is "use em up", I wonder if it is designed to salvage scrap MT3 tapers by grinding a flat on them? It could be worth asking on The home shop machinist forum. Edited By old mart on 04/01/2020 21:25:16 Plus 1 for this. I think the idea was that it would allow the use of a drill with a broken off tang. |
Michael Gilligan | 05/01/2020 00:16:56 |
![]() 23121 forum posts 1360 photos | Looks like I was wrong https://www.practicalmachinist.com/vb/antique-machinery-and-history/morse-taper-flat-side-114089/ MichaelG. . Should have paid more attention to the legend ‘3 to 4’ Edited By Michael Gilligan on 05/01/2020 00:19:31 |
John Reese | 05/01/2020 02:40:47 |
![]() 1071 forum posts | Posted by old mart on 04/01/2020 21:23:35:
Its made in Iowa, so it could be anything. I notice the name is "use em up", I wonder if it is designed to salvage scrap MT3 tapers by grinding a flat on them? It could be worth asking on The home shop machinist forum. Edited By old mart on 04/01/2020 21:25:16 Careful! Some Iowegians get testy over stuff tile that. If it came from Iowa it was probably made by Collis. They were called Use EM Up sleeves. When the tang twisted off a drill or the taper got too messed up to hold in its socket you could grind a flat on the side of the drill shank until it fit in the Use EM UP socket. I am 82 and have only seen maybe 6. Not common anymore. |
Clive Foster | 05/01/2020 09:26:37 |
3630 forum posts 128 photos | Having sorted out what it is the next question must be how did they make a sufficiently accurate D section taper back in those days? Obviously you can't ream it to size and broaching sounds difficult. I'd cut the side off a proper taper and weld or silver solder the flat on but thats very home shop guy. Clive |
DiogenesII | 05/01/2020 11:00:48 |
859 forum posts 268 photos | ..Broached? ..is there a wedge-slot at the back? ..it looks like one of those processes that sprang from their gun industry.. |
ega | 05/01/2020 11:27:55 |
2805 forum posts 219 photos | From old Buck and Hickman catalogue: I'm afraid this doesn't answer Clive Foster's interesting question. The reference to "Use-em-up" Type suggests that this was a generic item; in a perfect world such things would not be necessary! |
David Canham | 05/01/2020 14:45:05 |
![]() 50 forum posts 15 photos | Hi DiogenesII, how indeed were they made. I am back at the works tomorrow and will see if there is a wedge slot at the back. |
old mart | 05/01/2020 15:10:12 |
4655 forum posts 304 photos | I would bet on there being a slot in the back, why, because there is light showing in the photograph. Incidentally, the tang on Morse tapers is not intended to provide drive torque, that's what the taper is for. I would be interested to find out how that tapered hole with a flat was produced, magic maybe. Edited By old mart on 05/01/2020 15:12:46 Edited By old mart on 05/01/2020 15:15:22 |
Nicholas Farr | 05/01/2020 17:02:17 |
![]() 3988 forum posts 1799 photos | Hi, yet another catalogue entry below, this is a 1963 edition. Regards Nick. |
Nicholas Farr | 05/01/2020 17:25:36 |
![]() 3988 forum posts 1799 photos | Posted by old mart on 05/01/2020 15:10:12:
I would bet on there being a slot in the back, why, because there is light showing in the photograph. Incidentally, the tang on Morse tapers is not intended to provide drive torque, that's what the taper is for. I would be interested to find out how that tapered hole with a flat was produced, magic maybe. Edited By old mart on 05/01/2020 15:12:46 Edited By old mart on 05/01/2020 15:15:22 Hi, probably Regards Nick. |
old mart | 05/01/2020 18:06:35 |
4655 forum posts 304 photos | I still cannot see how that hole was produced, grinding would not do it as there are no rads on the interface between the taper and the flat. |
DiogenesII | 05/01/2020 18:12:02 |
859 forum posts 268 photos | I think Nick has it.. Hot forging in a die using a mandrel of the correct shape? |
DiogenesII | 05/01/2020 18:20:14 |
859 forum posts 268 photos | Similar to here, at 12 minutes in - different shaped part, of course, but same principle. https://www.youtube.com/watch?v=wUSgS7FHIds apologies, tried to embed but couldn't find sizing option.. |
old mart | 05/01/2020 19:29:12 |
4655 forum posts 304 photos | Yes, I cannot see any alternative to the hot forging of the bore, followed by conventional turning and grinding of the outside. It probably doesn't matter if the taper is not perfect, after all it is going to house damaged tapers anyway. The slot would probably have to be extra long if some tangs were missing. Edited By old mart on 05/01/2020 19:31:55 |
David Canham | 07/01/2020 18:25:57 |
The drift slot is also longer than a standard sleeve's slot. Note the hole in the side, most odd. All the best, |
