Adam | 03/01/2020 21:40:14 |
70 forum posts 81 photos | Hi everyone. I have acquired a power hacksaw from my grandfather which I shall restore. There are no manufacturers markings anywhere and I'm wondering if anyone can identify it. It's a flat belt drive so it must be very old. It turns over by hand and I look forward to using it. |
Adam | 03/01/2020 21:40:44 |
70 forum posts 81 photos | |
Steviegtr | 03/01/2020 22:01:24 |
![]() 2668 forum posts 352 photos | No idea but Alco springs to mind. |
Chris Evans 6 | 04/01/2020 08:13:38 |
![]() 2156 forum posts | My "Excalibur" (Spelling ?) machine has or did have a similar drive belt set up. Now converted to Vee belts. The saw Arm on mine is very different which may indicate either a totally different machine or a latter model. |
not done it yet | 04/01/2020 09:12:19 |
7517 forum posts 20 photos | I would suggest it is a ‘bitsa’ or more likely a modified/repaired machine. The piece of channel, with the weights attached, in the second picture does not be look like it was original? |
JohnF | 04/01/2020 12:16:06 |
![]() 1243 forum posts 202 photos | I don't think its a Bitsa but probably the motor has been added and it was probably made to be run off a line shaft ? Try putting "Vintage power hacksaw" into google then look at images -- there are many and you might find a look-a-like ? Interesting old machine and well worth restoring ! John |
Oily Rag | 06/01/2020 14:45:27 |
![]() 550 forum posts 190 photos | I would hazard a guess that it is a bit of 'Lend Lease' equipment dating from early 1940's - probably something like a Millers Falls manufactured in Massachusetts USA. It looks to be something which may have been used in a REME mobile workshop or a LAD (Light Aid Detachment) mobile workshop of the Royal Armoured Corps, or even the American equivalent. Small enough to do a competent job but not of overpowering size as would be required in industry. A few close up pictures may help! The finish on Millers Falls products was generally to a very high standard being black enamelled with red lining, but of course, war grade finish may have been the order of the day. Well worth restoring and a valuable tool in its' own right. |
Adam | 14/01/2020 18:45:52 |
70 forum posts 81 photos | Thanks everyone. I started grinding back old paint and found this on the cob rod. Any ideas? |
