Machining Axleboxes
Bruno Taylor | 03/01/2020 15:53:44 |
![]() 48 forum posts 14 photos | Here are two of the six split axleboxes l have just finished machining. The cast iron stock weighed in at 14lb. The six axleboxes weigh 1lb 4oz, a 91% wastage rate. I doubt if that's a record. Unless you know better. |
Martin Connelly | 03/01/2020 18:02:52 |
![]() 2549 forum posts 235 photos | I have some rotabroach type cutters. Where possible I use these to remove most of the metal from large holes as the waste slug out of the centre is useful raw material. I have just done some parts where some aluminium alloy slugs provided the material to make some cylindrical spacers. Martin C |
duncan webster | 03/01/2020 20:05:07 |
5307 forum posts 83 photos | friend of mine had a subcontract machining job in some exotic material, he made more selling the swarf than producing the components |
larry phelan 1 | 04/01/2020 09:50:07 |
1346 forum posts 15 photos | As my friend say,s "There,s money in scrap, lad " |
Michael Gilligan | 04/01/2020 10:19:05 |
![]() 23121 forum posts 1360 photos | Posted by Bruno Taylor on 03/01/2020 15:53:44:
. […] a 91% wastage rate. I doubt if that's a record. Unless you know better. . It’s certainly up there in aerospace territory, Bruno : **LINK** https://youtu.be/BWoUBMOlydI MichaelG. |
Neil Wyatt | 04/01/2020 14:19:12 |
![]() 19226 forum posts 749 photos 86 articles | As Captain Picard was wont to say "Make it so, Mr Swarf!" Neil |
JC54 | 04/01/2020 20:42:52 |
![]() 154 forum posts 14 photos | Now I understand why metal is so expensive. It must be a really skilled job to be able to pack all of that swarf into such a small volume |
TeVe | 04/01/2020 21:18:20 |
![]() 22 forum posts 11 photos | Posted by Bruno Taylor on 03/01/2020 15:53:44:
....... The cast iron stock weighed in at 14lb. The six axleboxes weigh 1lb 4oz, a 91% wastage rate. .......... Swarf Engineering ? |
Norman Rogers | 06/01/2020 14:43:58 |
20 forum posts 2 photos | I manage 100% swarf rates quite regularly but that's more usually known as scrap!! |
