Brian H | 29/12/2019 19:46:45 |
![]() 2312 forum posts 112 photos | I don't very often use a micrometer these days, preferring the digital six inch rule otherwise known as a digital caliper but I was doing a job that required that little bit more accuracy and so went in one of my measuring instrument drawers for a 0 to 1 mic. I realised that I have 4 very different ones to choose from and wondered if others might be interested. The picture shows, at the top, my first mic, a normal sized but elderly Brown & Sharpe. Below that is my first mic, another Brown & Sharpe but much bigger and heavier. Next is a quite modern TESA which is the one I normally use and finally, a GKN Shardlow digital but it's a mechanical digital and not an electronic one. Brian |
old mart | 29/12/2019 20:01:25 |
4655 forum posts 304 photos | If I could choose, it would be the Tesa. |
Chris Evans 6 | 29/12/2019 20:04:04 |
![]() 2156 forum posts | I have around 4 or 5 if I include the 0 to .5 Just bought a new 0 to 1 because the older ones, some I have had for 55 + years are getting harder to read. Until I got the new one my go to was a Mitutoyo I bought around 1970. Maybe when they where first imported ? All the old hands told me I was wasting money because it would not last. |
old mart | 29/12/2019 20:11:17 |
4655 forum posts 304 photos | We were left an 0-1" Mitutoyo mic in a legacy, it is one of their early ones, in a tiny box with a picture of their Tokyo factory inside. The early ones have slotted screws for the lock and ratchet. |
not done it yet | 29/12/2019 20:30:26 |
7517 forum posts 20 photos | Any one that reads zero when closed and is accurate when checked with a test piece at the 1” size? Lucky you, to have the choice of some decent examples. I would more than likely choose the 0-25mm one, but all to their preferred system. |
Michael Gilligan | 29/12/2019 20:58:48 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 29/12/2019 20:30:26:
Any one that reads zero when closed and is accurate when checked with a test piece at the 1” size? Lucky you, to have the choice of some decent examples. I would more than likely choose the 0-25mm one ... . ... which would fail your first test |
Oldiron | 29/12/2019 22:13:11 |
1193 forum posts 59 photos | Nice selection. I used to have a GKN Shardlow like the bottom one. I was gutted when it disappeared from my bench one day at work. Was always nice to use and accurate. regards |
