Michael Leckenby | 30/11/2019 14:40:23 |
3 forum posts | Hello, I am relatively new to larger model steam locos. I have what to most of you will be a rather naive question. I have bought an inline water valve to fit to the injector water supply of a 5" loco; one of those valves with a 4" long control. The shaft fits into the valve but doesn't engage with anything. What are the usual methods of locating this? I have seen grub screws and pins used. Forgive my ignorance but can someone advise me. Thanks M |
David George 1 | 30/11/2019 20:30:03 |
![]() 2110 forum posts 565 photos | Hi Michael welcome to the forum there are loads of people to give advice here but it helps if you give a locality and an indication of machinery etc. David |
Michael Leckenby | 30/11/2019 21:03:09 |
3 forum posts | Thanks, David. I am in Co.Durham. The loco I have is a 5" gauge 'Dougal'. It's a very basic slip eccentric loco but water feed relies only on either the bypass valve or hand pump. Therefore I am fitting a No 2 injector. There is plenty of room for pipework, etc. so I chose to use the inline water valve mounted under the cab floor. Now that I have the valve I can't see how the handle is fixed within the valve. |
Paul Lousick | 30/11/2019 22:47:56 |
2276 forum posts 801 photos | Hi Michael, (4" long control. The shaft fits into the valve). Are you refering to an extension for the valve spindle ? (Photo ?) If so, the normal practise on full size engines is to have a square sectiion on the end of the valve spindle and the extension rod has a head with a square hole that fits over the spindle. Paul.
Michael Leckenby | 01/12/2019 15:08:59 |
3 forum posts | Yes, that's right, Paul. There is a hole in the top of the valve spindle, The extension rod fits snuggly into that but both are circular so there's no way it can engage and open/close the valve. There is about 3/16" of the valve spindle proud of the valve mounting boss. It's not a lot but it may be enough to drill a hole through for a locking pin or even a slot. I am hoping the supplier will get back to me on Monday with their recommended method. Thanks for the reply, Michael |
JasonB | 01/12/2019 16:03:16 |
![]() 25215 forum posts 3105 photos 1 articles | Reeves suggest soldering the handle once the position of the valve has been established. |
