Member postings for Michael Leckenby
Here is a list of all the postings Michael Leckenby has made in our forums. Click on a thread name to jump to the thread.
Thread: In line water valve control
01/12/2019 15:08:59
Yes, that's right, Paul. There is a hole in the top of the valve spindle, The extension rod fits snuggly into that but both are circular so there's no way it can engage and open/close the valve. There is about 3/16" of the valve spindle proud of the valve mounting boss. It's not a lot but it may be enough to drill a hole through for a locking pin or even a slot.
I am hoping the supplier will get back to me on Monday with their recommended method.
Thanks for the reply,
Michael
30/11/2019 21:03:09
Thanks, David.
I am in Co.Durham. The loco I have is a 5" gauge 'Dougal'. It's a very basic slip eccentric loco but water feed relies only on either the bypass valve or hand pump. Therefore I am fitting a No 2 injector. There is plenty of room for pipework, etc. so I chose to use the inline water valve mounted under the cab floor. Now that I have the valve I can't see how the handle is fixed within the valve.
30/11/2019 14:40:23
Hello,
I am relatively new to larger model steam locos. I have what to most of you will be a rather naive question. I have bought an inline water valve to fit to the injector water supply of a 5" loco; one of those valves with a 4" long control. The shaft fits into the valve but doesn't engage with anything. What are the usual methods of locating this? I have seen grub screws and pins used. Forgive my ignorance but can someone advise me.
Thanks
M
