Positioning bushes for welding
sparky mike17/11/2019 11:01:39
259 forum posts
77 photos
I have to weld two 1" diameter steel bushes into two holes in a steel 3mm plate. How can I jig these up to be spot on square to the plate? They are not flush with the plate but protrude around 3/8" on the back side.
Mike.
pgk pgk17/11/2019 11:08:38
2661 forum posts
294 photos
The obvious answer would be a 3/8ths cup on the back and 3/8th supports or tack from the back if flush at the front. But I guess there's a reason why you can't do that. Won't the bushes get distorted anyway? Can you not weld some plugs and machine them out afterwards? Or rely on locktite?
pgk
ega17/11/2019 11:09:26
2805 forum posts
219 photos
I would tack them, check, adjust as necessary and then finish weld.
Daniel17/11/2019 12:09:49
338 forum posts
48 photos
+1 to ega's post.
Tack weld, adjust to final position, finish weld;
ATB,
Daniel
sparky mike17/11/2019 13:17:02
259 forum posts
77 photos
It has to very accurate so think this is the way I am going.
Thanks for replies anyway.
Mike.
sparky mike17/11/2019 13:19:51
259 forum posts
77 photos
Martin Connelly17/11/2019 13:29:43
2549 forum posts
235 photos
Welding and accuracy are somewhat mutually incompatible. The weld pool freezes at a high temperature and all the way from freezing to room temperature it is contracting and creating stresses. These stresses will distort the fabrication to some extent. Fabrications for tools and jigs have to be stress relieved after welding and before machining as a result. No matter how accurately you position them for welding expect some movement away from the ideal position.
Martin C
Dave Halford17/11/2019 14:26:23
2536 forum posts
24 photos
treat each bush as a compass.
Scribe the bush with the position of the plate
tack north, then south, then east, then west, like torqueing up a cylinder head.
Check the scribed line after each weld and adjust as required.
Your bridge is quite flexible so still expect some movement.
Nicholas Farr17/11/2019 15:06:21
3988 forum posts
1799 photos
Hi Mike, can you not turn a the end of the outside of the bush the required length and put in a smaller hole?
You will not stop distortion, no matter what you do, but it can be controlled by slight bowing of the plate before welding, but of course you will need some experience before you are able to do this satisfactory.
Regards Nick.
sparky mike17/11/2019 16:57:16
259 forum posts
77 photos
I made the simple jig, but instead of two welded legs to the bridge, I tapped the top plate and now have two 3/8" unf long threaded bolts in. I had thought about having each end of the bushes with turned spigots, but plate holes were in before I got to thinking on a bit.
Mike.
Brian Oldford17/11/2019 17:33:30
686 forum posts
18 photos
Weld in pieces of rod that have only been centre drilled. Weld into the plate getting them as square as possible the drill through with a mag drill.
Dave Halford17/11/2019 17:50:49
2536 forum posts
24 photos
Posted by sparky mike on 17/11/2019 16:57:16:
Mike.
You could weld a ring around each bush then turn that down to form a shoulder
John Reese17/11/2019 18:19:41
1071 forum posts
My preference would be a bush with a shoulder on the OD to set depth and squareness.
sparky mike17/11/2019 20:53:26
259 forum posts
77 photos
Hi John,
A solid round piece of bar , counter bored to the depth of the bush overhang and a good fit on the o/d of the bush, in conjunction with my jig on the other end should work well. Hope for a warmish day in the workshop tomorrow !!
Mike.
