Andy Sproule | 12/11/2019 10:44:39 |
122 forum posts 35 photos | Hi,I have one of these lathes both power feeds are working and lathe is in as new condition tried everything I can see but can't get the screw cutting to engage.What am I missing? |
JasonB | 12/11/2019 13:12:20 |
![]() 25215 forum posts 3105 photos 1 articles | Should be able to engage it by using the horizontal lever to the right of the apron, not the one to engage feeds |
Emgee | 12/11/2019 13:13:35 |
2610 forum posts 312 photos | Hi Andy, go to the link below and join the Boxford forum, you may even find a manual in the Files section. https://groups.io/g/BoxfordLathe-UserGroup Emgee |
Andrew Evans | 12/11/2019 13:15:33 |
366 forum posts 8 photos | Is the leadscrew turning? |
Andy Sproule | 12/11/2019 13:43:54 |
122 forum posts 35 photos | Thanks for replies.Yes the lead screw is turning and I have tried the leaver.Posted question on Yahoo boxford group aswell.It came from a school there wouldn't by any chance be some sort of lock on it? |
JasonB | 12/11/2019 13:58:54 |
![]() 25215 forum posts 3105 photos 1 articles | Got a feeling that the push/pull feed selector needs to be in the mid position eg so that neither facing or length ways feed can be selected, feed lever down then the other lever should engage the halfnuts while the screw is turning. If feeds are working which you say they are then screw will be turning. Edited By JasonB on 12/11/2019 13:59:44 |
Phil JOHNS | 12/11/2019 15:18:59 |
19 forum posts | Yes JasonB is correct, I have a simplified operating instruction sheet for that lathe and could PDF you a copy of the relevant pages if you PM me an email address |
Andy Sproule | 12/11/2019 15:38:55 |
122 forum posts 35 photos | PM sent Phil. |
Andy Sproule | 12/11/2019 18:09:04 |
122 forum posts 35 photos | Its sorted folks I was able to look underneath with a mirror and with some very gentle tapping on the slide of the half nut and wiggling the leaver it eventually freed up.Thanks again for all your help. |
