Manofkent | 23/10/2019 22:08:47 |
145 forum posts 29 photos | I am now starting the tender for 3.1/2 gauge County Carlow. The plans specify 18g brass sheet, and the sides are made from 20 inch lengths.
So can anyone suggest a supplier I might try. All my usual sources seem to stop at 12 inch lengths.
Very many thanks
John |
Baz | 23/10/2019 22:21:37 |
1033 forum posts 2 photos | Pretty sure GLR will do 24 inch lengths but not on their website, you may have to phone and ask. |
Rockingdodge | 23/10/2019 22:25:35 |
![]() 396 forum posts 111 photos | Try M-Machine at m-machine-metals.co.uk, they price by the foot but will cut to your requirements and charge accordingly. Roger |
Adam Mara | 24/10/2019 09:18:54 |
198 forum posts 1 photos | I might be able to help if your are unsuccesful in obtaining elsewhere. My son is an engraver and uses 600mm x 1200mm engraving brass sheets for solicitors signs and similar. I know he uses 1.5mm or thicker normally, but I think there may be 1.0mm or 0.9mm. PM me if you are interested, I'm on holiday in deepest Dorset at the moment, and won't be in touch with him until the weekend! |
Neil Wyatt | 24/10/2019 09:51:15 |
![]() 19226 forum posts 749 photos 86 articles | I made the platework for Southam from the remains of a meter square brass sheet that was quite light gauge, so definitely available. |
D.A.Godley | 24/10/2019 15:32:46 |
143 forum posts 41 photos | I am sure you will find what you require if you talk to ; John Keatley (Metals ) Ltd , Shadwell St , Birmingham , B4 6HD 0121 236 4300. www.johnkeatlymetals.com . I have no connection other than that of a satisfied customer . |
roy entwistle | 24/10/2019 16:36:04 |
1716 forum posts | John If you you need to bend it, engraving brass is not suitable, it will crack Roy |
Kevin Murrell | 24/10/2019 16:59:16 |
59 forum posts 6 photos | Fixed web link: **LINK**
Mike Crossfield | 24/10/2019 17:54:00 |
286 forum posts 36 photos | John, Try Ian T Cobb at www.clockmaking-brass.co.uk. He stocks a wide range and will cut to pretty much any size. Mike |
Dave Shield 1 | 24/10/2019 18:44:50 |
33 forum posts 6 photos | Use M-machine, Very good service |
roy entwistle | 24/10/2019 18:46:46 |
1716 forum posts | John Clock makers usually use engraving brass, not suitable if you have to bend it Roy |
Mike Crossfield | 24/10/2019 20:03:59 |
286 forum posts 36 photos | Despite the name of his website, Ian Cobb supplies a range of different brass, not just engraving brass. Mike
Essm | 24/10/2019 20:05:48 |
29 forum posts 8 photos | Blackgates Model Engineering in Dewsbury will cut any size you need and charge by weight |
roy entwistle | 24/10/2019 20:38:06 |
1716 forum posts | Mike I was just making sure that the OP new what he was asking for Roy |
Manofkent | 05/11/2019 09:35:30 |
145 forum posts 29 photos | Just to update this post. Thanks to everyone for your suggestions. Eventually I went with John Keatley metals. (Thanks D A Godley). They were happy to supply a few other small bits of steel I wanted (like 30mm lengths) and prices for the brass were very good. They even saved me £20 Plus VAT on postage by discussing what I was using it for and suggesting an appropriate cut to the Brass. Well recommended, and they even answer the phone!
John |
D.A.Godley | 05/11/2019 22:16:10 |
143 forum posts 41 photos | Posted by John Hilton on 05/11/2019 09:35:30:
Just to update this post. Thanks to everyone for your suggestions. Eventually I went with John Keatley metals. (Thanks D A Godley). Well recommended, and they even answer the phone!
John John ; So very pleased you found what you required and that they saved you a few pence , it always helps . I had absolutely no doubt that they would be able to satisfy you . regards , David |
