Gandalf is broken
duncan webster22/10/2019 18:44:04
5307 forum posts
83 photos
We have a small statue of Gandalf as a garden ornament, stands about 18" tall made from some kind of plastic. It is hollow, varies between about 1/16 and 3/16 thick. SWMBO managed to knock it off the table and smash it to bits (thank the Lord it wasn't me). I've araldited it back together and filled the bits which couldn't be rescued with car body filler, but it is still riddled with cracks. Next step is to fill it with some kind of gloop which will set and re-inforce the structure. I reckon I need a pint or so, must not shrink on setting or it will be loose, neither expand or it will burst him asunder. Anyone got any suggestions.
Oldiron22/10/2019 19:16:56
1193 forum posts
59 photos
How about using plaster of paris ? I have used it on ceramic statues and works well. Not sure how good on plastic.. Maybe use an etch primer first to help it adhere.
Ian Skeldon 222/10/2019 19:20:48
543 forum posts
54 photos
Epoxy resin with fine fibreglass matting chopped into very small pieces?
Neil Wyatt22/10/2019 20:29:35
19226 forum posts
749 photos
86 articles
You have my sympathy if your wife can prevail where a balrog failed...
Aliphatic glue works well on similarly constructed meerkats (long story...) but it's too late now.
Expanding polyurethane will work as long as you keep it vented, as it's very liquid when first introduced.
old mart22/10/2019 20:32:51
4655 forum posts
304 photos
Get one like this, she won't be able to knock it over.laugh
Brian Oldford22/10/2019 21:00:48
686 forum posts
18 photos
G26 two part resin.
pgk pgk22/10/2019 21:03:01
2661 forum posts
294 photos
It's often a question of what's to hand. Waterproof PVA swilled inside then stuff gently with newspaper or old rag bits soaked in the same.
pgk
DMB22/10/2019 21:04:16
1585 forum posts
Chuck it away n get a noo onedevil
Graham Stoppani22/10/2019 21:36:10
157 forum posts
29 photos
Builders expanding Foam Filler such as this?
No Nonsense Expanding Foam Filler
Jeff Dayman22/10/2019 21:59:41
2356 forum posts
47 photos
Once it's back together and smoothed up, make a sand mould and cast a second one in aluminum! No more delicate resin.
Only half kidding, you could do a wood form box and make a plaster mould or a wax mould (one time use) and cast a new G in concrete or urethane casting resin. A "core" of capped plumbing pipe held in the mould could be used to reduce material amount needed.
David Standing 122/10/2019 22:43:49
1297 forum posts
50 photos
Builders fizzy foam is definitely the answer!
Bazyle22/10/2019 23:47:46
6956 forum posts
229 photos
The foam might well burst it apart. Don't try to fill it 100%. Do like clay statues and chocolate bunnies. Pour a limited amount of resin or some such in, swill it around and pour the rest out (into some other mould). Allow to dry and maybe repeat but only to build up a thinnish layer inside, not a completer fill.
Speedy Builder523/10/2019 07:22:12
2878 forum posts
248 photos
I have a similar problem, my "Little girl" made of cast cement around about 1900 lost an arm, a leg, head dropped off and fingers on the good arm have frost bite. I have re-modeled with modeling clay, and am about to purchase molding rubber etc, then cast in bronze epoxy. "She" sounds about the same size as Gandalph. She was my grandmothers pond 'nymph', then lived with my aunt at her pond, then with my mother at her pond - and guess what, this winter's project is to make a pond !!
Neil Wyatt23/10/2019 14:15:42
19226 forum posts
749 photos
86 articles
Baby Jesus in our nativity set has his left foot replaced with an epoxy putty prosthetic. Similar surgery restored one of the angels to flight-ready status.
