tom hardy | 18/09/2019 12:24:54 |
30 forum posts 1 photos | where can i buy steel reinforced lifter hose for a 1 1/2 traction engine tom hardy |
Brian Sweeting | 19/09/2019 14:57:53 |
453 forum posts 1 photos | What size tube are you looking for and material type? There is a good range of 'plastic' reinforced tubing available. |
JasonB | 19/09/2019 15:04:16 |
![]() 25215 forum posts 3105 photos 1 articles | Quite a few makers get a small rubber hose and then wind thing galvanized wire around it. You can leave as that or add a layer of self amalgamating tape. MJ Engineering do some suitable black rubber hose for just that job Heritage steam sell scale water lifter hose but only for the large scale engines |
Clive Brown 1 | 19/09/2019 15:16:27 |
1050 forum posts 56 photos | For the 1 1/2" Allchin, W Hughes described wrapping tinned copper wire around 1/4" rubber tube. He suggested grey tube, which is not common, and fuse wire, 10 or 15 amp, I forget which, but it's 0.015" dia or 28 swg. His method was to wrap 3 lengths of wire side by side, then remove 2, to give the spacing. |
Oldiron | 19/09/2019 15:20:55 |
1193 forum posts 59 photos | Nip over to your nearest hydraulics & hose supplier or agricultural outlet. Depending where you are you could try these people. They will always help the small user. Hose supplier regards Sorry just noticed you are in WA from your earlier posts. The info should be of help to yourself and others though I hope Edited By Oldiron on 19/09/2019 15:22:18 Edited By Oldiron on 19/09/2019 15:25:27 |
Trevor Drabble | 19/09/2019 15:25:07 |
![]() 339 forum posts 7 photos | As per Jason's suggestion , Blackgates also sell a selection of suitable hose in different diameters. Trevor. |
tom hardy | 21/09/2019 00:52:22 |
30 forum posts 1 photos | thank you people for the info well done tom |
Neil Wyatt | 21/09/2019 21:37:41 |
![]() 19226 forum posts 749 photos 86 articles | I came across a suggestion of winding a loose spring with hard stainless steel wire, then inserting it into a tube of heat-shrink tubing. I imagine it isn't very flexible, but not sure how much you need it to bend. Neil |
Nick Clarke 3 | 22/09/2019 09:46:32 |
![]() 1607 forum posts 69 photos | Does it need to be steel reinforced or to have the appearance of steel reinforced? In an article about making vacuum brake pipes W.A (Bill) Carter described how to wrap wire around a pipe and run an electric current through it to burn the appearance of the corrugations into the pipe. If you need it I will dig out the reference to the issue. Nick |
