Wire in drawers
Mikelkie | 07/09/2019 22:07:53 |
![]() 135 forum posts 13 photos | |
Mikelkie | 07/09/2019 22:09:19 |
Edited By Mikelkie on 07/09/2019 22:11:05 |
Mikelkie | 07/09/2019 22:09:44 |
Neil Wyatt | 07/09/2019 22:34:15 |
![]() 19226 forum posts 749 photos 86 articles | Looks like a stock boxes for a seller. 'Piano' wire is very hard and can be brittle if bent too far so it furtehr work hardens, good for pivots and pins and some springs. Iron wire is soft and easily bent to shape. I imagine the 'hard steel wire' is intermediate. Neil |
Cornish Jack | 07/09/2019 22:38:10 |
1228 forum posts 172 photos | Much used in model aircraft , for push-rod ends and similar. Almost anything requiring thin high strength - lantern pinions for clocks maybe? Very useful stuff, particularly as you appear to have a number of different gauges. rgds Bill |
old mart | 08/09/2019 16:19:16 |
4655 forum posts 304 photos | Swedish made top quality steel. The iron wire is commonly used for holding things together while they are being brazed or silver soldered. The piano wire and the hard steel would be of interest to horologists |
larry phelan 1 | 08/09/2019 17:43:24 |
1346 forum posts 15 photos | I seem to remember that Hitler used piano wire to strangle people he did not like. I suppose it has other uses as well. |
SillyOldDuffer | 08/09/2019 17:54:54 |
10668 forum posts 2415 photos | Wild guess - part of a piano repairman's outfit. As the wires all appear to be the same size, I'm thinking of the rods that connect piano keys to their hammers. Three grades of rod giving different degrees of spring might be handy for adjusting how the hammer whacks the strings. Dave |
Martin Hamilton 1 | 08/09/2019 18:36:05 |
188 forum posts | Piano wire is also what they use to run tethered cars & hydroplanes on, very strong wire indeed but must be looked after re even the slightest kink in the tether wire must be replaced. Needs to be strong when a 16 lbs flash steam hydro is running at over 130mph & an electric tether car is running over 220 mph. |
