Ian McVickers | 23/08/2019 22:33:40 |
261 forum posts 117 photos | Boufht myself a new lathe quick change tool post and decided to have a go at making some holders. So 30mm thick plate, 240mm long 85mm wide, on the mill surfaced up. Dovetail slot roughed out to depth and started cutting the dovetails. Anyway don't know how I managed it but i`ve cut the dovetail slot 0.5mm too wide. So I really don't want to have to scrap the plate so I could weld up one side and recut it, probably killing the cutter in the process or I could make a shim and pin it to the top of the holder to keep it in place. Any other options to save the bar? |
Paul Lousick | 23/08/2019 23:22:09 |
2276 forum posts 801 photos | Instead of a pin to secure the shim, could you use Loctite instead ? Another option is to braze or silver solder to build up the surface. Then re-machine to size. Not so severe on your cutter. Paul. Edited By Paul Lousick on 23/08/2019 23:25:31 |
John Reese | 24/08/2019 00:58:22 |
![]() 1071 forum posts | If it is an Aloris clone it would be faoirly tolerant of dovetail width. Try it on the toolpost before doing anything else. I have some oddbaall toolholders with a dovetail slightly too large for the toolpost. I use a shimcto make them work. |
Ian McVickers | 24/08/2019 10:47:45 |
261 forum posts 117 photos | Thanks guys. It is an aloris type and it does grip the blank tool holder but its right at its limit. I will try out a shim with some Loctite and see how it goes. I`ll need to be more careful with the next batch. |
DC31k | 24/08/2019 17:28:54 |
1186 forum posts 11 photos | If there are many holders and only one toolpost, could you shim the toolpost itself? |
Ian McVickers | 24/08/2019 19:01:37 |
261 forum posts 117 photos | This is the first batch. I will get 5 or 6 from the current bit of bar but I'm planning on making more and also getting the next ones right. |
Neil Wyatt | 24/08/2019 22:32:17 |
![]() 19226 forum posts 749 photos 86 articles | I made a batch of a dozen holders, one was a tad too deep so I glued a shim to the bottom of the dovetail (not the angled side) and it's still going strong. Neil |
Bill Pudney | 25/08/2019 01:30:04 |
622 forum posts 24 photos | I did exactly the same thing with some toolholders. The problem was cured with a steel shim and JB Weld. There were two problems, P1,clamping the shim in place, required a small bit of mylar as a release agent, to ensure that everything wasn't stuck together forever, and P2 leaving the toolpost and toolholder clamped up for 24 hours whilst the epoxy cured. Best of luck, cheers Bill |
old mart | 25/08/2019 14:24:22 |
4655 forum posts 304 photos | You could hold the shims with a couple of 2mm countersunk screws, if you are up to tapping small holes. |
