What are these off
Found while clearing dads workshop
Mike Lightfoot08/08/2019 22:23:35
76 forum posts
24 photos
  • Good evening just found these i believe they are change wheels but dont match any machine dad had so does anyone have any idea
  • cheers
Emgee08/08/2019 22:45:06
2610 forum posts
312 photos
Hi Mike
Could be Colchester Bantam, if you count the teeth and measure OD and post the figures, the DP can be calculated which will help identify which machine they will be suitable for. Dimensions of the centre and splines will also be helpful.
Emgee
Mike Lightfoot08/08/2019 22:57:10
76 forum posts
24 photos
Emgee, thanks will do that first thing tomorrow
Bazyle09/08/2019 01:06:16
6956 forum posts
229 photos
Some Colchester info here though it is slightly confusing.
I.M. OUTAHERE09/08/2019 05:10:00
1468 forum posts
If they don’t fit any of the machines your Dad had is it possible he may have been using them for indexing purposes ?
Clive Foster09/08/2019 10:19:21
3630 forum posts
128 photos
Looking at the labels on the dividers the gears mostly appear to be in steps of 4 or 8 teeth. If so they are a set of differential dividing gears for a dividing head as 4 (or multiples of 4) tooth steps are usual for the normal dividing head with 40 to 1 worm reduction.
The splines look similar to those used by Elliot / Victoria, Cincinatti, Edgewick, Hoffmann et al.
The Elliot set is 24, 24, 28, 32, 40, 48, 56, 64, 72, 86, 100
If the gears are for a spiral milling set up there will be a variety of other gears to generate the various leads.
For example Cincinatti supply 17, 18, 19, 20, 21, 22, 24, 27, 30, 33, 36, 39, 42, 45, 48, 51, 55, 60. But the Cincinatti heads have rather more holes in the dividing plates than normal, especially if you have the wide range set, so differential indexing is rarely needed. That set is more for generating leads.
Edited By Clive Foster on 09/08/2019 10:44:30
John Paton 109/08/2019 10:26:05
327 forum posts
20 photos
I love the storage rack
With one like that you could have your lathe in the lounge!
Edited By John Paton 1 on 09/08/2019 10:27:40
Tony Pratt 109/08/2019 10:50:12
2319 forum posts
13 photos
Yes off a dividing head, used similar back in the 70's
Tony
old mart09/08/2019 13:51:32
4655 forum posts
304 photos
The six splined shaft fitting should be a clue. A measure of the bore as well as the diameters/teeth count and gear thickness should do it.
Bazyle09/08/2019 17:30:26
6956 forum posts
229 photos
Although the 86 is normally the indicator for a dividing head set the 48 is not normal for that so might be a set of pick off gears for the feed on a large mill. If they are 10DP and the splines are 1&1/8 at the max part then they are Kearney & Trecker and I would be interested if you want to sell them.
Clive Foster09/08/2019 18:27:03
3630 forum posts
128 photos
Bazyle
I'm a little surprised to hear that 48 is an unusual tooth count for differential dividing gear sets as all the listings I have include it as do to the two sets of unknown origin I (should) have about the place. (I've not seen one set for 15 years but pretty sure I haven't sold it.).
Anyway I took another look at the numbers on the shelves of that very nice case and the contents are correct for Elliot / Victoria as there are two 24 tooth gears. So far as I'm aware Elliot and the associated companies were the only folk to use that particular duplicate.
Mike Lightfoot09/08/2019 20:30:54
76 forum posts
24 photos
image.jpgimage.jpgFirst of all thank you all for your time, some more info, the larger inside bore is 1.04” the smaller is .85” .5 width
two pictures here of 64 and 24 tooth wheels and dia the first 64/4.123 is 15.5 second 24/1.615 is 14.8 since to calculate dp i believe they should be measured at the pcd and not the od would that be right for 15 DP?
Mike Lightfoot09/08/2019 20:35:07
76 forum posts
24 photos
My only other observations are even with a cabinet like that swmbo would not have the lathe in the lounge they were only allowed in for the picture, knowing Dad he just bought them because they looked nice he had two dividing heads so wouldnt really need them for indexing
thanks for looking
not done it yet09/08/2019 21:21:08
7517 forum posts
20 photos
For DP, add 2 to tooth count and divide by OD. They are 16 DP
Mike Lightfoot09/08/2019 21:32:07
76 forum posts
24 photos
Not done it yet, thanks i didnt know that one
Emgee09/08/2019 22:11:37
2610 forum posts
312 photos
My Bantam gears are 16DP.
Many years ago I had a 5" Victoria dividing head but the drive on that had a single keyway, not multi spline as these gears.
Emgee
Bazyle09/08/2019 22:34:25
6956 forum posts
229 photos
Posted by Bazyle on 09/08/2019 17:30:26:
Sorry, my mistake. It is the 44 that is 'off-key' and not listed in Clive's earlier list of the Elliott gears. The B&S tables also show you don't need 44 to meet all the necessary ratios. As an aside I've always admired the way some past engineer managed to work out the best set of gears for this application without any of the modern computing support.
