How to remove
martyn nutland | 03/08/2019 11:33:31 |
141 forum posts 10 photos | Hello I wonder if anyone could advise on this? I have an Austin Seven flywheel from which I want to remove the ring gear. This is the early type where the teeth were milled(?) onto the solid. I.e. not the type where you heat a gear ring and shrink it onto the flywheel. Most people would probably do this on the lathe and I have sufficient swing to do that. However I am worried such a heavy interrupted cut will bash the hell out of the lathe headstock. I'm thinking a gentler approach would be to mount the flywheel on a rotary table and cut down just behind the teeth with an end mill or slot drill. Is this a sound tactic? Thanks in advance for any help. Martyn
PS Not an angle grinder please! They terrify me.
Howard Lewis | 03/08/2019 13:24:38 |
7227 forum posts 21 photos | Suggest that you get your ring gear first, so that you know what diameter to turn the the flywheel down to. To minimise hammering the lathe too hard, take things gently with a fine feed and shallow depth of cut. Lots of minor smacks as against a few sledgehammer blows, would be my approach. If the lathe can swing an Austin 7 flywheel it will be fairly large, heavy and rigid. Good luck! Howard |
fishy-steve | 03/08/2019 13:41:59 |
122 forum posts 30 photos | Could you chain drill the centre out and finish the bore on the lathe? Alot quicker than milling. As Howard says. A lathe that can swing that diameter should be able to manage intermittent cutting. Steve
Nigel Graham 2 | 03/08/2019 14:50:30 |
3293 forum posts 112 photos | Alternatively, use the lathe but trepan the teeth off? (Equivalent to using the rotary-table and slot-drilling.) |
Pete Rimmer | 03/08/2019 15:44:35 |
1486 forum posts 105 photos | If you can swing it just turn the teeth off. Use a carbide fit for turning interrupted, or a hefty lump of HSS with not much rake to preserve the edge. |
Robert Atkinson 2 | 03/08/2019 15:45:43 |
![]() 1891 forum posts 37 photos | I'd use a angle grinder (or toolpost grinder) with a ttin cutting disk to take the teeth off. Tidy up with grinding disk before turning to size. Robert G8RPI. |
Nick Clarke 3 | 03/08/2019 17:38:03 |
![]() 1607 forum posts 69 photos | +1 for angle grinder |
martyn nutland | 04/08/2019 08:19:56 |
141 forum posts 10 photos | Very many thanks everyone. That helps. Martyn |
old mart | 04/08/2019 14:22:21 |
4655 forum posts 304 photos | I second Howard Lewis's approach. You need to know what interference fit the new ring gear will need and how wide it is, as a shoulder is required on the flywheel. Try a file on the teeth, if they are not too hard, then your lathe should cut them off with no problem, using carbide inserts such as TNMG. Remember to set up the flywheel the right way round for the shoulder. |
Neil Wyatt | 04/08/2019 21:01:10 |
![]() 19226 forum posts 749 photos 86 articles | Posted by martyn nutland on 04/08/2019 08:19:56:
Very many thanks everyone. That helps. Martyn Not bad, you only got about 30% angle grinder suggestions Neil |
John Reese | 04/08/2019 22:13:52 |
![]() 1071 forum posts | Martyn, It seems your lathe is robust enough to handle the interrupted cut. I say chuck it up and have at it. Rig some kind of sheet metal deflector to clamp over your tool to keep the cast iron chips from flying everywhere. |
