Jon Cameron | 15/07/2019 20:08:15 |
368 forum posts 122 photos | Hello, I recently bought a job lot of rusty tools, the reason for buýing them was this lovely bunch of tools that were hidden amongst the pictures. There is also a marking out gauge which I was wondering if this was featured as a build in ME or if someone could identify the maker. The fixed and travelling steady are up for sale if anyone is interested. As they are for an ML10 I believe so won't fit my ML4. How do I go about cleaning the rust off the surface of the tooling? Lastly what is the other faceplate with a spigot on it, anyone used or have one of those as I've not seen anything like it before. |
Bazyle | 15/07/2019 20:25:13 |
![]() 6956 forum posts 229 photos | There are quite a lot of threads already on here about rust. If you go to the website front page, not the forum front page and use the search box there it will come up with some. Quite a lot of options but for this light rusting ignore the brick/patio cleaner options. I think the spigot o the faceplate is not part of the original and just fitted for quick mounting in a 3 jaw. The faceplate itself looks like a Picador one or one from a drill powered wood lathe. |
Former Member | 15/07/2019 20:32:43 |
1329 forum posts | [This posting has been removed] |
Vic | 15/07/2019 20:40:39 |
3453 forum posts 23 photos | Battery charger and washing soda works really well and doesn’t etch the surface like acid will. |
Brian H | 15/07/2019 20:50:19 |
![]() 2312 forum posts 112 photos | I recently tried Evapo-rust from Frosts, removed all rust and left a matt grey finish that doesn't re rust immediately. Very pleased with it, and you can re-use it until it no longer works. Brian |
Spurry | 15/07/2019 21:16:42 |
227 forum posts 72 photos | Citric acid crystals dissolved in warm water, work very well, and give good results...cheaply. Pete |
Andrew Tinsley | 15/07/2019 21:19:27 |
1817 forum posts 2 photos | Hello Jon, I have sent you a PM. Regards, Andrew. |
old mart | 15/07/2019 22:50:39 |
4655 forum posts 304 photos | A lot of that stuff will respond best to a bit of wire wool and 3 in 1 oil or WD40. Use thick pvc gloves. If the faceplates are to be used in a lathe, then a light facing off will kill two birds with one stone. Edited By old mart on 15/07/2019 22:53:16 |
ega | 15/07/2019 22:55:00 |
2805 forum posts 219 photos | At first sight I thought the faceplate could be from GHT's UPT. |
Jon Cameron | 15/07/2019 23:11:44 |
368 forum posts 122 photos | Thanks for all the replies, i think ill try the citric acid crystals first on the calipers. From what ive been reading from bazyles suggestion is that electrolysis can leave raised sections of black stuff, so could effect the accuracy of any surfaces, and strong acids can eat into the surface of the metal. Evapourust seems to be a good one without any harmful chemicals but is still costly to buy in any quantity. So for me it's the crystals and then maybe the evapourust. Cheers again Jon |
Jon Cameron | 15/07/2019 23:16:34 |
368 forum posts 122 photos | Posted by ega on 15/07/2019 22:55:00:
At first sight I thought the faceplate could be from GHT's UPT. That's what I was wondering......I remember seeing pics of it before. |
Spurry | 16/07/2019 09:34:39 |
227 forum posts 72 photos | Posted by Jon Cameron on 15/07/2019 23:11:44:
Thanks for all the replies, i think ill try the citric acid crystals first on the calipers. From what ive been reading from bazyles suggestion is that electrolysis can leave raised sections of black stuff, so could effect the accuracy of any surfaces, and strong acids can eat into the surface of the metal. Evapourust seems to be a good one without any harmful chemicals but is still costly to buy in any quantity. So for me it's the crystals and then maybe the evapourust. Cheers again Jon From my experience with the citric acid, keep your eye on it when you have dunked the bits and pieces. The rust disappears, the metal takes on a nice silvery sheen, but if left too long the metal can get discoloured. It is quite a long temperature-dependent process though. Pete
