Ref Lawrence Sparey
Mike Waldron | 03/07/2019 11:25:25 |
51 forum posts | Good morning all: |
Clive Brown 1 | 03/07/2019 11:34:16 |
1050 forum posts 56 photos | Expanding mandrels are useful, but i'd think that accuracy could be an issue, With the ER system, the concentricity is maintained by the 16 deg. taper solidly mounted on the machine spindle. With the expanding system, keeping the taper concentric with the machine spindle would be more difficult. Clive Edited By Clive Brown 1 on 03/07/2019 11:47:32 |
John P | 03/07/2019 13:59:46 |
451 forum posts 268 photos | Posted by Mike Waldron 03/07/2019 11:25:25
The collets seen here in the photo are for grinding 4 facet drills They are similar to what you have in mind for these internal collets. As you can see these have 8 saw cuts ,after all of the turning The material is silver steel unhardened,the largest is about 3 1/4 John
Mike Waldron | 03/07/2019 14:21:50 |
51 forum posts | John: thanks for that. Mike |
John Haine | 03/07/2019 14:57:36 |
5563 forum posts 322 photos | Somewhere I have seen what you describe, either home-made or as a product, afraid I can't remember where.
Aha! Our friendly universal supplier. Edited By John Haine on 03/07/2019 14:58:34 |
Thor 🇳🇴 | 03/07/2019 15:42:08 |
![]() 1766 forum posts 46 photos | Hi Mike, If you mean "collets" for an expanding mandrel, like this: They are not difficult to make. When the topslide is set for taper turning I use the same setting both for turning the taper of the mandrel and the collets in the same setting. I turned the taper in more collets than I needed so I have some spares. For slitting I just used a small hacksaw. Thor Edited By Thor on 03/07/2019 16:07:46 |
Mike Waldron | 03/07/2019 21:38:54 |
51 forum posts | Thor: thanks for that. Can you recall what angle you made the taper? Also what sizes do the collets / arbor sleeves cover?
Thank too to you others for you input also. Mike Edited By Mike Waldron on 03/07/2019 21:40:25 |
Neil Wyatt | 03/07/2019 22:16:04 |
![]() 19226 forum posts 749 photos 86 articles | You can buy sets of the expanding mandrels. Stub claims he's on a diet so he's a shrinking mandrel at teh moment. Neil |
John Reese | 04/07/2019 00:37:21 |
![]() 1071 forum posts | Expanding collets are made. Here is an example for a watchmaker's lathe:**LINK** At one time I had a similar collet in 5C size. At the time I didn't have a lathe so I gave it away. |
Thor 🇳🇴 | 04/07/2019 05:52:07 |
![]() 1766 forum posts 46 photos | Posted by Mike Waldron on 03/07/2019 21:38:54:
Thor: thanks for that. Can you recall what angle you made the taper? Also what sizes do the collets / arbor sleeves cover? Mike Edited By Mike Waldron on 03/07/2019 21:40:25
Hi Mike, I made the mandrel many years ago so I don't recall what angle I used, but the "narrow" end is 14.2mm dia., the "big" end is 22.3mm, the length of the tapered section is 85mm. The thread at the narrow end is MF14 x 1 since I happened to have a MF14 x 1 tap. I have got a smaller expanding mandrel as well, I have a tapered reamer that I used to crerate the taper in the small collets. The mandrel itself is made from a high carbon steel (0.8 to 1% C) and mild steel for the collets. I hope that helps. Thor Edited By Thor on 04/07/2019 05:52:44 |
John Haine | 04/07/2019 09:39:29 |
5563 forum posts 322 photos | I wonder if one could use MT tapers? Could form the "collet" bore with an MT reamer, and use an off the shelf arbor for the "chuck". |
Thor 🇳🇴 | 04/07/2019 14:18:00 |
![]() 1766 forum posts 46 photos | I would think that using an MT reamer is one way to make the "collet" bore, good idea John. Thor |
Mike Waldron | 10/07/2019 20:19:49 |
51 forum posts | Would that not cause a jam up? Is that not the whole purpose of a morse taper? Mike |
Thor 🇳🇴 | 11/07/2019 05:11:57 |
![]() 1766 forum posts 46 photos | Posted by Mike Waldron on 10/07/2019 20:19:49:
Would that not cause a jam up? Is that not the whole purpose of a morse taper? Mike The mandrel I made has a taper not far from what you find on Morse tapers and the sleeve will hold even if the nut isn't used. I use a brass drift to knock the sleeve off. I have used the sleeve to finish turn gear wheels and pulleys so I need a good grip. Thor |
Howard Lewis | 11/07/2019 16:29:13 |
7227 forum posts 21 photos | Bell Chucks are, or were, available, in both internal and external forms. Probably more used by clockmakers, but very useful for holding thin material, such as washers. Not really suited for holding material that hangs out far, since the length to grip is short (circa 1/16"or 1.5mm for the modernists ) Expanding mandrels have to be the way for longer workpieces, within reason. For one offs, just turn up a suitable arbor. Wish that I could remember what some of mine were made for! Howard |
old mart | 11/07/2019 19:37:53 |
4655 forum posts 304 photos | I have often thought of buying a set of the expanding mandrels for odd jobs such as bushes. I believe they require pre-setting very slightly over the size of the workpiece bore and then skimming to size to ensure a good fit and also to run true. |
